99 Camaro V6 3800 Injectors Question
What's is the stock fuel rail pressure ?
I want to put #26 LS1 injectors on it.
I've found
48-55 psi (ignition ON)
3-10 psi loss at idle
Don't help me to convert the LS1 injectors data ...
Stock Injectors : 22 lbs (AC Delco 217-306)
ok it's useless.
The pressure is 42 PSI.
LS1 #26@58PSI are 22@42PSI
Is that really all your FPR is set to?
In the W body its set to maintain 58 PSI across the injectors under all conditions.
