Can anyone confirm HP Tuners VATS disable for the above works?
This is a eng swap, eng in 1985 Truck
Here is the current file if someone cares to take a peep.
Anyone???
Wish I could help... When it comes to swaps and stuff of that nature, I am not the guy. I hope someone will chime in for you!
Andrew
2006 Duramax ECSB - Banks Monster Dual Exhaust, Tie Rod Sleeves, Kennedy Twin Deluxe Lift Pumps, Edge Insight CTS with Pryo, EGR Blocker Plate, PVC Reroute, Suncoast Stage 5 trans with 1056 triple disk converter, Cognito Steering Braces, PPE Race Valve, LML driver side exhaust manifold, AFE Boost Tube, Stock Drop-in BatMoWheel, ProFab Performance 3" Downpipe, Other mods along the way, TUNED by ME... Way too much fun
It looks disabled in your tune. I've disabled the vats on other swaps by using the same switch you did, works fine.
Thanks guys
Is there a way to test inj pulse on a duramax?
