Ok, heres the deal, i have a 1992 GMC Sonoma GT, similar to the Syclone just no turbo and 2WD instead of AWD, and they only made 806 of them.
Im rebuilding the whole truck from the ground up, and was orginally going to build a 5.0L Turbo V6 Monster, but have decided that the reliability i want can tbe had in such a radical motor.
So i have ditched the V6 and gotten an LQ9 6.0L block, that i plan to put in a eagle forged bottem end in it, 4in stroke crank, 6.100 rods and JE flat tops, ported LS6 heads, 11.1 or so CR and the LS1 Hot Cam and full Comp valvetrain with 1.85 rockers. FAST Composite Intake and 90MM TB.
Anyways, my questions is what is the best engine harness and PCM to use in my truck with said engine, camaro, or vette or a truck harness and computer, also should i get the speed denisty option, i plan to spray the engine with a 200 shot of gas also.
I would also like to be able to hook up my stock chassis and cab harness so that al my guages still work and the like, and have the OBD-2 connector in my stock location under the column.
Im thinking the VCM Suite 1.7 with the 1 bar speed density option and the enhanced cable.
Oh, and im planning on reusing my stock(althouht fully built) 700R4 trans and 3500 stall lock up converter, will this be possible?
Sorry this is kinda long, just need some answers, im getting parts together now, to get the engine built and then its on to the computer and wiring.
