Results 1 to 9 of 9
Thread: This may be a stupid question but...
    Feb 2012
    5
    If I'm reading correctly, I can purchase HPT and upload the GMS1 tune as a starter upgrade. Can I do this without the MAP upgrade?
    And also, can someone just confirm that the GMS1 tune is available for free after in the HPT tunes list for each vehicle?
    Aug 2007
    503
    Since you can alter the map scaling you don't need the 3bar maps.
    Finding a gmpp tune in the repository is no guarantee, which car do you have?
    Dec 2008
    Nevada
    4,452
    I don't think there are any in the repository. Hpt wouldn't allow it when it was released so we pass them around privately
    Feb 2012
    5
    This would be for a 2008 HHR SS
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Stock base file modified for the 3 bar MAPs is the way to go. Less turbo nanny in the stock base file than GMPP in tables we cannot access.
    Or you can boost above the control range of the 2.5 bar MAPs on the stock file & run 'out of control'
    You cannot run the GMPP file without changing the sensors and if you modify it to match your stock sensors you will most likely see less boost above 5k rpm but I never tried it personally.
    Jan 2007
    22
    So if I had the dealer flashed the gmpp calibration in my ecu would I be able to access it with Hp tuners?
    Jul 2009
    2,305
    Yes, but why?
    The info to run the 3 bar MAPs on the stock file and tune it is already in this forum.
    You can do better than the GMS1 base file with the stock base file.
    Buy the sensors & pigtail adapters from Performance Autowerks or CED and do it yourself.
    Jan 2007
    22
    I just received this car and apparently it has a custom os in it with all the map sensors installed. So I'm trying to figure out if I should have the dealer flash it back to stock or
    Have the gmpp tune put in it or if I can plug in a tune that l already have and do a write
    entire but I was told that I couldn't do that so I haven't tried.
    Jul 2009
    2,305
    Post the tune after you do a read entire. It may be already a stock file OS and 3 bar MAP data.
    Some tuners (like me) prefer this combo.
    If you are uncomfortable posting the tune at least post the numbers from the ECU OS and the MAP sensor data.
    Need to know the model year and vehicle also to see if it matches.
