Results 1 to 2 of 2
Thread: IAC (idel Air Control )
    Dec 2011
    28
    So the idle air control valve I understand when its on a throttle body its a plunger motor which the pcm counts in steeps to let air in for idle conditions . Like on the c4 corvettes and some ls1 engines
    What the hell I cant figure out for the life of me is on a C5 corvette with fly by wire TB. The right side is your TPS sensor, the left side is a servo motor that turns the plate.
    In HP tuners Under Idle, Airflow , General there is a whole area for IAC settings , Where is it in the car or is the software just emulation it in the main servo motor steps. I can not see any way it could since nothing even comes closes to making logical sense on my gauges with temps times pressures ect
    I have been tweeking these settings and have found good and bad with my issue of transition from closed throttle to 8-13 % TPS and 1-3% peddle position sensor
    In hp tuner scanner I have a gauge set up that when cold starts around 220 then after running ends up around 125. While driving anywhere for 125 to 199 max ????
