So, you guys tell me your opinions here because this is driving me up the wall.
Basically, this is another issue with my truck where my STFT's at idle are freaking out. I.E.(Bank 1, -2.3, Bank 2, +14.1%) now get this though, at part throttle and WOT both banks are perfectly well behaved. Only at idle is this issue present.
Engine is a 415 LS3, port/polish LS3 heads, Kenne Bell 3.6 supercharger, decent sized 236/245 cam on a 114, and ID1000 injectors.
I've recently changed plugs, inspected gaskets, changed plug wires, changed O2 sensors, and it's still going nuts.
Is this the cause of the design of the intake manifold or do I need to pull the supercharger and rails off to clean the injectors?
Kinda lost here because nothing in the tune could allow it to do this, and the worst part is that the Wideband confirms that the O2's are responding correctly.
Any thoughts?
Thanks guys.
