you use same like you said, so you dont get any knock learn
you use different if you want the car to get knock learn. Consider it like the LTFT except for knock. This is a stored value to pull timing. Same way fuel trims work (kinda). With no knock learn, you still get knock but its like the STFT, it wont remember it each time you hit that cell but it will have to respond to the sensors to pull timing each time.
