Results 1 to 3 of 3
Thread: TPS 10-13 % pedal 1-3%
    Dec 2011
    28
    What table is causing my ARF to come down in the 11.5 range when my TPS is in the range of 10- 13 % and or my peddle sensor 1-3 percent. ????
    if my foot is all the way off the gas peddle its fine.If its 4 percent or higher its awsome.
    Any time the tps or is 10 to 13 is running rich
    Just getting little stumble when I am cruzing and basically just have my foot bairly on the peddle then move it a hair more into a small stumble then car is perfect and arf are too ....
    Its a hp tuner OS 2 bar sd tune I am thinking is has to be something with the idle airflow tables ...
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Sounds like you have electronic throttle control to me, nothing to worry about.
    Dec 2011
    28
    Pulled off my T/B found some back lash in my butterfly ... Along with a fine dusting of metal ... around the plate shaft .... It was not very clean on the back side ether ...
    Anyone ???? whats the normal amount of free play ..... Please tell me NON At all. Time to get a New TB next
