Results 1 to 14 of 14
Thread: how can i tune the cutoff ??
    Potential Tuner almansouri's Avatar
    Mar 2012
    dubai
    4
    Question how can i tune the cutoff ??
    Hi ..
    i am tuneing me v8 gmc 2004 5.3 ,,
    so i would like to ask how can i make the car sound like shooting when it is cuting off the rbm >>
    Advanced Tuner Atomic's Avatar
    Jun 2008
    455
    ...sound...like...shooting.....you mean bounce off the rev limiter? Put it in neutral and press the pedal down.
    Oct 2007
    346
    he actually wants the car to bounce off the limiter in gear, there is a way to do it, did it before just to test it works, took some trial and error.
    Jun 2008
    455
    set the rev limiter below the shift point? I fail to see the purpose of this...
    Aug 2011
    18
    Quote Originally Posted by Atomic View Post
    +1
    Advanced Tuner oakley6575's Avatar
    Aug 2011
    421
    hahaha in for a video!!
    2003 Chevy Silverado Daily Driver, 408 Iron Block,
    LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
    Oct 2007
    346
    it doesnt work, you will just ride on the limiter, he wants to BOUNCE off the limiter, vom vom vom vom vom vom sort of thing lol, there is a way to do it, and people like doing this stuff in this part of the world, they also tune the backfire beleive it or not, you pay $500 just to tune how you want your car to backfire, go figure...
    That sound is made when extra fuel is not burned in the engine so it goes to the exhaust pipe which is hot and therefore is burned there. I've never done that but probably not letting the truck going into DFCO (check HPTuner's help for that).
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    I'm fuckin amazed:
    Just use Spark control to accomplish this. No ETC cutoff, no Fuel Cutoff. That'll get the job done. I think command torque is -600 ft.lbs so that should lend a -30 to -40 degree timing spark advance, which will make it pop and bobble and do all that crap.
    I get flames when I bounce it off the limiter on my car.
    618/618 motor
    906/862 spray
    Same principle, unburned fuel (because of spark) goes to the hot exhaust pipe.
    Aug 2010
    Roswell, N.M.
    1,956
    Which is then ignited at the collector instead of the combustion chamber
    618/618 motor
    906/862 spray
    Jul 2005
    271
    Quote Originally Posted by IDRIVEAG8GT View Post
    Which in turn throws flames out of the tailpipe. Gets red hot, people still yelling "more more" then finally your bumper fascia melts and catches fire.
    /faceplam
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by HoP View Post
    /faceplam
    Damn straight!
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Reading the first post in this thread still makes me giggle. :P
    618/618 motor
    906/862 spray
