Results 1 to 12 of 12
Thread: Fueling issues...
    Mar 2011
    46
    Fueling issues...
    Here's a link to my rlf post, cant upload files here on my ipod but i'll try later if needed
    http://www.redlineforums.com/forums/...tml#post982437
    The obvious answer is that i have a fuel supply issue, but its so odd that the afr jumps up to nearly 14.7 in a sudden move... Just thought some of you guys might take a look; maybe there's something i haven't thought of yet...
    Advanced Tuner 383_Stroker's Avatar
    Apr 2009
    258
    Quote Originally Posted by armcclure View Post
    If you're seeing a pressure drop, the pump isn't keeping up with demand. Pump on its way out, filter clogged, etc?
    Did you have this trouble before you installed the 1000s?
    Mar 2011
    46
    Yes but nowhere near as bad. I changed the filter last night with no change.
    I have just never heard of a pump "going" out; usually all or nothing. Still possible though.
    I'll be dropping the tank tomorrow to check it out.
    I did change E85 stations a few months ago... Maybe their tanks aren't as clean as where i used to go and the in tank sock it getting plugged up?
    Dec 2008
    Nevada
    4,452
    also check the pump inlet sometime shit gets past....time for a aeromotive drop in or walboro pump.
    Mar 2011
    46
    Aeromotice doesn't like e85 but a walbro might be the next step...
    I'll keep you guys updated with what i find out. Thought about just adding an inline booster pump...
    Dec 2008
    Nevada
    4,452
    i used a walboro with my supra nvr had any problems with it. both good companies but yes walboro is more run whatever fuel you desire friendly.
    Apr 2009
    258
    Dumb question.... how much fuel is in the car?... anything below about 1/8th in my car and it runs out of fuel, very similar looking to that..lol
    Mar 2011
    46
    Its a fair question. It does act that way on low fuel. But i did those logs on a half tank. A guy on RLF had a similar problem and it ended up being black gunk from the e85 clogging up the bottom of the canister and sock. Guess i'll find out tonight.
    Mar 2011
    46
    Dropped the tank and cleaned the sock out last night; helped a little but still pulling lean and dropping pressure. On a 3rd gear pull i saw the gauge literally drop over 25psi before i even had time to react. New pump time
    Mar 2011
    46
    Well i have a DW300 and pro-products adjustible regulator on the way; doing boost-reference system and hardwire kit. This had better take care of it l
    Dec 2008
    Nevada
    4,452
    good luck hope it works.....switch to return system? cause they tune different
    Mar 2011
    46
    Just to get it running i may leave the vac line on the regulator off and run it like the stock system while i make the fittings and such i need but yes i'll be going to full return system.
