Results 1 to 18 of 18
Thread: 07 supercharged vette lots of knock
    Dec 2006
    Fort Lauderdale
    171
    I have never seen anything like this...car has 6psi,small cam and I have the total wot advance at 6 degrees just putfresh 93 octane and car has lots of knock...total scanned advance is -6 degrees...that is right negative.
    Afr is solid 11.4 across board.
    What could this be?
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    if its high compression engine ( very high ) u need fuel
    or
    you might wanna play with your timing
    or it could be false Knock
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Dec 2006
    Fort Lauderdale
    171
    Quote Originally Posted by vette_c6 View Post
    or
    Its stock ls2 motor with a baby cam
    Jun 2008
    Kuwait
    390
    then you need to confirm if its a False or real KR
    posting a file and Scan would help us to Figure whats going on
    Abdullah Al-najdi
    00965 99369929
    Dec 2006
    Fort Lauderdale
    171
    added scan to OP
    Jun 2008
    Kuwait
    390
    to much Low timing man
    you can send me your file and i will have a look at it
    i need to increase the timing
    even check your engine Delevery Trq
    Abdullah Al-najdi
    00965 99369929
    Dec 2006
    Fort Lauderdale
    171
    For some reason this crap internet im on wont let me u/l the tune...i know its low now but its only because when i had it at 12* it was knocking 10* and i had it at 18* and was knocking 12*...so for now i have it low low...
    Jun 2008
    Kuwait
    390
    dunno man ,, if u need more help ,,,
    wait for more expert guys then me
    or shot me with your file and i will see what can i do
    Abdullah Al-najdi
    00965 99369929
    405
    2,342
    MAP sensor reads 57-67 kPa through the WOT run. Looks like it is 1/2 what it should be for 6 psi. I'd address that first. IATs are 144-160 degrees doesn't help but even with it that hot you should be able to run more timing than that. Airflow in the histogram looks low. Is this a MAF or SD tune?
    Jun 2008
    Kuwait
    390
    thank God that you said its reading 57-67 KPA
    i thought its something in my histograms
    because i played with it to make Boost ,,, but it start reading in - ( the KPA ) and then i fixed it ,,,
    anyway ,, u are totally right
    i will attach a Car with boost
    look at the KPA
    this car is not boosting ( i beleive )
    Abdullah Al-najdi
    00965 99369929
    Don't overlook the spark plugs. 1 or 2 ranges colder isn't even enough sometimes. With all of the new high tech plugs you might have to go drastically colder.
    Mar 2008
    34
    what kind of blower?
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    6 psi and a small cam should be fine with TR6 spark plugs, and you should be able to run almost 20* of timing at the top end. What's the IAT's getting up to? And have you disabled BKR?
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Aug 2010
    Roswell, N.M.
    1,956
    Is this tune scaled for injectors, if so, you might have forgot to do a manual scale on the knock sensors.
    618/618 motor
    906/862 spray
    Dec 2006
    Fort Lauderdale
    171
    Quote Originally Posted by IDRIVEAG8GT View Post
    Well the car has 65# injectors but has an LS7 maf so the ifr table is close to stock. Car runs great and afr is solid in idle and part throttle and wot is dialed in nice.
    it is an eaton roots blower. iat's are getting a bit high. But your comment here interests me. What is the manual scale on the knock sensors?
    And no I havent disabled burst knock, but I can. Should I? Just disable BKR and leave it disabled completely?
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by boostls2 View Post
    Well, if you scaled the tune for the injectors, the knock sensor level needs to be scaled the corresponding amount as they are g/cyl referenced.
    I personally as a tuner disable BKR completely. I hate it. Others will disagree but whatever. I find it useless when trying to tune out real knock.
    Is the knock that you are hearing audible? If so and you're running a TR6 plug, a gap change may be in order as well.
    618/618 motor
    906/862 spray
    Dec 2006
    Fort Lauderdale
    171
    What table are you referring to?
    Jul 2005
    271
    Spark / Knock Sensors / Airmass Min
