First, I'm sorry for the cross-post. I posted 3 different threads in the past 3 days and not received a single reply on any of them. When I bought HPT a huge reason was because of the reportedly amazing forum where there is so much participation and so many people willing to help. Hoping for a little more action in this section. If a mod or someone wants to delete my other post that is fine by me. I wold have done it myself if I had permission.
I have an LS2 in a custom application that does not need or use many of the things listed in the instructions. So my question is, what of the below are REQUIRED for the CASE relearn to complete successfully and what is just BS listed for safety reasons?
Per VCM Scanner help files:
CASE Learn: To use the CASE learn function please follow these steps:
1. Put the vehicle into park (auto) or neutral (manual) - NP, but I don't have a PNP switch, so is the VCM looking for that signal or is this just telling idiots to be safe?
2. Turn off all accessories and A/C. - NP, I have no accessories or AC.
3. Turn the vehicle off.
4. Apply the parking brake. - I have no parking brake and therefore no parking brake switch. Is the computer looking for one?
5. Press the brake pedal. Keep the brake pedal depressed during the entire procedure. REQUIRED for successful test completion - I have brakes but no brake lights and therefore do not need a brake switch. Do I have to apply power to the terminal at the VCM to trick it into thinking I have the brakes depressed?
5. Start the vehicle and let it idle.
6. Press Begin.
7. Gradually rev the vehicle to fuel cutoff (around 4000-5000 RPM's) over a period of about 4 seconds. When fuel cuts out, immediately release the throttle. - I have an LS2 and have not modified the fuel cutoff settings. They say my cutoff is 6600 rpm???
8. Allow the engine to come back to an idle.
9. Turn the ignition off for at least 15 seconds. This step is required for the VCM to store the newly learned configuration.
Thanks for the help.
J. J.
