Results 1 to 7 of 7
Thread: 2011 camaromap sensor?
    Mar 2012
    oklahoma
    4
    so after 4 days of trying to figure out software things are getting easier a couple of questions. What map comes on the camaro stock and i could not get the ve genorator 3.5 to work even after loading .net 3.5 framework. The car has cam full exhaust, pro charger, 65lb injectors, 2500 stall. also could some one try explaining how adjusting map,map2,rpm,rpm2,and map.rpm and the constant has a positive or negative effect on afr and ltft, stft. its really been hit or miss and i think i have but the map is throwing my tune off. Also after all this computer 1 week old completely crashed while scanning and test drive
    Dec 2009
    So MD
    132
    I know some disagree but I would try running on pure MAF and forget about VE.
    Mar 2012
    oklahoma
    4
    Smile
    Quote Originally Posted by Roger Ramjet View Post
    Ok Any hints on acieving a goal like this, I have done maf tuning on dsm's but not with a tuning system like this
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    how much PSI are you running ?
    i can post you a start up file if you want to
    post your file and send me a pvt msg with your email
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Mar 2012
    oklahoma
    4
    Procharger Stage 2 D1-SC 10 psi, jba longtubes, JBA midpipes c/delete, JBA 3" mandrell pipes, compcams muthathumpr grind, fast 65psi inj., PI/2500 converter, vvt & dod delete.
    Jun 2008
    Kuwait
    390
    i had a car to tune
    i havent touched the engine and havnt touch any of it
    but the car was Stroker 414
    magnasun tvs 2300
    it was running 13 PSI then slip back to 8 psi
    on the stock Camaro 2010 MAF ,, it was fine ,,
    i asked the guy ,, what have he done with the car
    he said Fuel system
    3 bar map sensor '
    but the OS is 2 bar
    they havent change the maf ,, BUT they got bigger pipe the one between the MAF and the magnasun
    this info might help u ,,
    the i runned the car on PURE MAF
    Abdullah Al-najdi
    00965 99369929
