Thread: Logging AEM 5 bar for exhaust pressure
    Feb 2010
    9
    This shouldn't be hard, but having trouble. I'd like to log exhaust pressure with this AEM 5v sensor (30-2131-75). I have the voltage table, but not sure on the next steps within EIO input.
    In the scanner, i'm under...
    Aux Input list, User Defined, Configure user defined, then what?
    AEM Data on sensor: http://www.aemelectronics.com/files/info/30-2131-75.pdf
    Thanks for any help guys.
    -Rob Melcher
    2004 GMC RST: 4.8L/Turbo/E85: 617HP/623TQ
    http://www.youtube.com/watch?v=V9nRm6vZl_I
    91 Eagle Talon 2.0L/Turbo/E85-10.61@136, 570AWHP Mustang Dyno
    http://www.youtube.com/watch?v=yB9kDxXRLgw
    Feb 2010
    9
    Think I got it figured out. Would I be correct in going under "list", then entering the data -14.700 at .5, then 60.300 at 4.5. Then clean it up taking -14.700 down to .0 and 60.300 up to 5.0
    Advanced Tuner sarg's Avatar
    Aug 2011
    Atlanta, GA
    305
    I would think that entering in the exact voltage that the sensor calls for would be the best way. Other wise all readings will be off. Try it with the recommended setting and make sure it reads 0 or close to it with the car off.
    Jun 2008
    Charleston, SC
    969
    (Volts/((volt range)/scale range)+(lower limit)
    Using PSI
    (Volts/((4.5-0.5)/(-14.7-60.3))+(-14.7)
    (Volts/(4.0/75)+(-14.7)
    Volts/
    0.0533333333 + -14.7
    Using KPA
    0.0077556 + 0
    -Carl
