First off thanks for taking a look.
Here's the run down. Forged LS7 11.0:1 comp, AA supercharger with 3.125 pulley making @ 12psi, AA supercharger cam (do not know the specs), AA redrilled injectors ( supposed to flow 63.5 lb/min @ 43.5).
I doubled the stoich, edited .50 for the injectors. Tuned the VE and she is great all the way to 4400 rpm's.
Tuned the low maf to within 2% and the high maf up to 7,400 hz to within 2% as well.
Under wot you can see from the log the injector dc ramps up 4000 rpm's. At 4,600 It appears that I'm going back into some serious vacuum according to the g/cyl. Any ideas why this is happening? My commanded AFR (11.3:1) is spot on up to 4700 then she starts to lean out. According to the MAF I still have room to grow before it's tapped out.
I've seen this before when the VE at the given rpm range is to high causing the injectors to work to hard to maintain the commanded AFR. The car right now is laying 690 rwhp at 5500 rpm's.
I appreciate your time, thanks.
