Results 21 to 40 of 41
Thread: ZR1 - Stock Injectors Limit
  1. #21
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    well then ,, lets see how much will i get from the 441 with 300 shot nitrous ,, few days for the dyno
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
  2. #22
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    Quote Originally Posted by Brice View Post
    nice ...
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
  3. #23
    Mar 2008
    Paris, France
    435
    Quote Originally Posted by vette_c6 View Post
    i am still waiting for STOCK files ,, and after adding extra boost ,,, the most think that i would like to see
    is under TQ mang supercharge
    Supercharger -> Boost disable ->
    Map disable : 256
    Map enable : 246
    I've got a ligenfelter tune under my eyes : very disapointing. MAF only tune, some idle stuff, PE hack and stock high octane table.
    The only thing I can get is that they modify the fuel pressure module parameter :
    they lowered
    -the low flow upper from 119 to 79
    -the low flow lower from 79 to 49
    http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
    Check our Facebook page http://www.facebook.com/lsxcalibration.com
  4. #24
    Mar 2008
    Paris, France
    435
    wait ....
    The ZR1 is FPCM equiped.
    I can play with fuel pressure so ... with injectors capacity ...
    No needs for bigger injectors ...
    Has someone experience with FPCM ?
  5. #25
    Jun 2008
    Kuwait
    390
    you are totally right man ,, ,about that fuel business ,, i guess i'll ask a few experience guys ,, i'll give one of them a phone call ,, and after i have the update ,, i will update u cheers mate thanks
    Abdullah Al-najdi
    00965 99369929
  6. #26
    Mar 2008
    Paris, France
    435
    the ZR1 has an interresting table on injectors parameters :
    Injectors Flow Rate vs Pressure Delta...
  7. #27
    Jun 2008
    Kuwait
    390
    dude ,, i loved u and i added u in the hp forum
    heheheh if you need any help ,, u can always pvt msg me ,, i will do my best to help good luck ,, and keep us updates
    Abdullah Al-najdi
    00965 99369929
  8. #28
    Jun 2005
    Southern FL
    2,044
    Yes, the factory ZR1 runs 6-bar (87 psi) at full flow, which is also the limit of the system (has a built-in pressure regulator that does not allow higher). Remember, the higher the pressure you run the more the pump you use.
    On modded ZR1's at 650 rwhp and above (Actual, not Corrected), I use Siemens 60# shorty injectors (flowmatched only, along with Greg Banish's injector data), then lower pressure from factory to 4.5 bar (65 psi, what the CTS-V runs), which allows for enough injector and pump beyond 700 rwhp (again, Actual). Raise pressure accordingly to achieve greater numbers, but be wary of the factory pump maximum (add a BAP, as needed).
    Now, keep in mind, the fuel system is not boost referenced (not a 1 to 1 system), so I'd suggest not lowering pressure below 65 psi, otherwise the injectors will become too small to support the added power as the boost is raised. The 60s will support around 725 rwhp (Actual) on a boost-referenced 3-bar (39.5 psi) system (ie 03-04 Ford Cobra). So on a GM with the non-referenced ERFS (electronic returnless fuel system) subtract boost from actual fuel pressure to get the pressure drop across the rail (ie 65psi - 15# = 50 psi). You can log this, FYI (it's inferred).
    Formerly known as RWTD
    Toys: '22 Tesla Model S Plaid / '20 Chevy Duramax / ?20 Sea-Doo RXT-X (2)
  9. #29
    Mar 2008
    Paris, France
    435
    Thanks for the information!
  10. #30
    Jun 2008
    Kuwait
    390
    Quote Originally Posted by RWTD View Post
    Yes, the factory ZR1 runs 6-bar (88 psi) at full flow, which is also the limit of the system (has a built-in pressure regulator that does not allow higher). Remember, the higher the pressure you run the more the pump you use.
    thanks for the good info ,,
    if you dont mind correcting me if i am wrong
    tuning a ZR1 with pully and headers with exhust and cam
    to reach 700 RWHP
    need 60 fuel injectors with data ,,
    make sure the fuel pressure not below 65,, because with 15 psi , it will drop down to 50 psi
    tune the car and enjoy life ,,
    the pic below , shows that the ZR1 injectors are lower then 60 so by getting 60 we are having a bigger injectors
    so it does make sense like that
    as a car come ZR1
    the only thing that i have to ask the customer to get ,, is the fuel injectors 60 with the data ?
    or there is something else ?
    the fuel pressure
    i havent looked at a ZR1 engine yet
    so do i ask only for a gague fuel pressure , ? and have a look at it ?
    and it will be around 60 ?
    or i have to get a Fuel Regulator to play with the fuel pressure ?
    i will be very greatfull if you tell the step by step how to do it ,, from a bone STOCK zr1 to pulley changed + full exhuast system + injectors + Camshaft
    what is the step by step job
    i am not asking for teaching me how to tune ,, but i need to have the step by step job
    the tuning part is easy ,, the preparing part for the car is weird and new for me ,,
    because usally when i tune a Forced induction car ,, it already comes with fuel system + injector ,, and fuel reg 1+1 with boost
    but this car ! is a new issue for me ,,
    thanks
    Abdullah Al-najdi
    00965 99369929
  11. #31
    Mar 2008
    Paris, France
    435
    As 88 psi is the limit.
    stock : PE tune only (my experience)
    Pulley : boost limit tune + classic tune
    H/c/pulley > 650 rwhp change injectors (rwtd)
    To be continued...
  12. #32
    Jun 2008
    Kuwait
    390
    To be continued...
    waiting for your further update ,, i had a strange issue today with GMC Sierra 2012 i am talking to billl in the email ,, he is helping after finishing i will upload all the subject ,,,
    waiting for your update guys
    Abdullah Al-najdi
    00965 99369929
  13. #33
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Or... run ID850s, enjoy better idle quality, and huge amounts of flow that allow the factory pump to run at a lower pressure thus increasing fuel flow rate out of the pump, eliminating the need for a BAP. Win win.
    http://www.dsxtuning.com
    Just say no to bull s***.
  14. #34
    Oct 2011
    22
    Pretty close to what I found today... hit 655whp at 116IDC at 70-72PSI at the rail. Time for more injector!
  15. #35
    Mar 2008
    Paris, France
    435
    The answer is 116% Duty cylce
  16. #36
    Jun 2005
    Southern FL
    2,044
    Old thread, I know, but I did have enough fuel pump and fuel injector (was using the Siemens shorty 60s back then) to make 750 rwhp Actual on a 2010 ZR1 with E85 (this was approx 2 years ago now)! This was even using the factory 87 psi limit. Impressive factory pump, for sure! IDC was 105% (oops) at redline (6800), Inj Delta Pressure was 58.x, and Injector Flow Rate of 78.x#. I had him shift at 6400, where he was under 100% IDC. I should have played with the Fuel System Minimum Voltage. On pump gas (E10), the numbers were IDC 66% at redline (6800), Inj Delta Pressure was 72.x, and Injector Flow Rate of 87.x#.
    As for what Dsteck stated about using ID injectors, I couldn't agree with him more. The SD shorty 60s do work nice with Banish's data, however, but I prefer the IDs. Sometimes it's hard to convince the customer to spend double on the injectors, unfortunately.
  17. #37
    Mar 2008
    St. Louis, MO
    4,859
    I deal with this a lot (people not wanting to spend the money). I'm lucky enough to be in a position to just say if they can't do it right, then they need to go elsewhere for a tune. It's no skin off my back... just means another night I can actually spend at home tinkering in my mad scientist lab. Lol.
  18. #38
    Tuner in Training SAM_69's Avatar
    Mar 2011
    Chicago.IL/Jeddah.ksa
    23
    wich i wanna visit
    good discussion keep it on guys
    EFI Tuning Specialist
    Chicago.IL
  19. #39
    Mar 2008
    Paris, France
    435
    I've put the Siemens 60 (Greg Bannish Data) on it and the the Cadillac CTS-V FPCM values , worked fine ;-)
  20. #40
    Mar 2008
    Paris, France
    435
    Rwtd, just a question about your Fuel Pressure parameter : do you modify only the normal and high flow pressure to 65 or keep all the parameter from the cts-v.
    I'm currently working on the ZR1 (we changed the pulley).
    I tune the MAF on the dyno (not wot) on low pressure (1500 to 8000 hz) : 50 PSI as CTS setting
    When I got wot and go high flow, the afr error is richer than on the low flow.
    I'm uqing greg bannish datas.
    Why not keep 65 PSI all the way ? (low,normal, full).
    I think deal with a constant pump pressure will simplify the tune (as a regular tune).
    What do you think about that ? (just thinking about it burning the midnight oïl)
