take a look at this log and tell my why it goes rich as soon as it reaches @ 170*
This is a OLSD tune using the MAF.
'02 Corvette
LS6, MN6, LT's/X pipe and TI's, Honker CAI, AI 243 heads, PatG Custom Cam, FAST 102, LS2 TB, Red Top inj, HPTuners & NGK/AFX
It happens right around 7 min and 50 seconds which is 480 seconds.
Check this out: Afterstart enrichment initial adder modifier vs soaktime
The value goes up exactly at 480 seconds.
Not 100% sure thats it, but see what happens if you change the value at 480 to the same value at 420, then relog and see if it then gets richer the 2nd log at 540 seconds. Pretty sure thats it tho, the timing is awfuly suspicious.
2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
wow, nice find. I'll give that a try and see if it follows it. I have noticed if I take it for a drive that it corrects itself over time.
since it's a multiplier should it be a 1 in that area?
'02 Corvette
It should taper gradualy to one as it warms up.
Did you make the change, and was that it?
I have only had a chance to try it one time but what I did is change the table from 120 up to all 1
something effected it but this time it went lean. I'm not sure what is happening around when the temp gets around 170*
'02 Corvette
I wonder if the MAF could be causing it to act funny in that range. I might try a cold start in just SD and see what happenes
'02 Corvette
Hmmmm! Something that has always driven me crazy with mine & the reason I never liked OL idle. When restarted after it is heat soaked it idles very lean & unstable for a period of minutes, of course in CL it corrects that, when OL it is not very nice.
These tables look like what I need modify to correct that problem.
Awesome tip....Tx's
ok I got around to trying the same tune without the MAF and it's doing about the same thing as the last log, going lean about 7 1/2 minutes after start.
is it normal to go to the "Afterstart enrichment initial adder modifier vs soaktime" table and adjust the section where it's going lean now?
'02 Corvette
Normal as in every day, no - but its more common with cams. Make some changes gradualy and see how it likes it, then keep us posted.
can this be Zero'd out? i'm assuming this is to help the car warm up, i'm in south florida, why do I need this?
- 02 Z06, LS2, Twin Turbo
