like it says im in need for a base tune.
i have a 383 lt1. 24x conversion, bosch 160lb injectors, e85, 8:1 comp, twin 72's turbos, 210 afr comperetion heads, and i want a sd tune.......
please help a guy out.
send me the base file to check it out
post your file
specialize in: V8 Tuning (Kuwait)
Abdullah Al-najdi
00965 99369929
www.youtube.com/alnajdi83
Tuners ! Quit Raping your PE TABLE !
instagram : alnajdi83
best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
sorry. whats a base file? im not a programmer.
this is what i have.
SD tune
383 lt1, 8:1 compression
24x (411 pcm)
aem driver box
twin 72 mm turbos
e85 gas
is this what you want?
Do you have your own HPtuners?
Ironically enough, I'm working on an almost identical setup right now.
email=[email protected]
I dont have one right now. im getting one this summer, Im In the process of learning, I probably can get a hold of one.
OK, well, a setup like that, you'll need more than just a typical "mail order" tune. You need someone on your end with the tuning tools. I can sell you a mail order tune, and as long as you have someone with the tuning tools, I can help you get it dialed in.
I also sell HPtuners. Send me an email, and we can discuss what you need to get your project running. [email protected] is my email.
Where you live?
My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
Why won't you contact Carl?
2012 Chevy Cruze A6 1LT RS
Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
i sent carl a meassage on are local form. i did that first. and minnesota
close to fargo we could get together to read the ecm
