2005 Corvette, Vortech supercharger.
GT500 Ford injectors, Boost-a-pump.
When the engine reaches ~4700 rpm at WOT the AFR jumps from 11.0 to 15.5 then leans out off the scale and the car feels like it is hitting fuel-cut rev limiter.
MAF Hz flat-lines (instead of climbing) for a fraction of a second and then drops to 0 Hz.
TPS stays at 88% (WOT) and my analog boost recorder shows boost continuing to climb. The car will rev past 6000 rpm at half throttle with no problem. Fuel pressure holds steady at 58 psi.
I tried a new MAF with the same results.
Datalog and tune file attached. What am I missing?
(Wideband is not connected to the datalogger so ignore those numbers)
