Results 1 to 19 of 19
Thread: 6.0 maggie tune
    6.0 maggie tune
    could someone please check out this tune i have been working on for my 2006 lq9 with a 112 maggie. I just added a 90mm j-tube and 60lb injectors from five-0-motorsports. this was all done on sunday and since then I have been
    trying to get the trims in line. Im concerned about how much fuel i had to add in the lower cells of the ve & maf. Tell me if im way off course.Engine is all stock except for blower, headers.
    03 SS Silverado,tvs2300,ID850,gt2-3,kooks, PRC 317'S,
    Feb 2006
    Canada
    1,963
    Looks close man. You are a little rich between 20% and 40% TPS and a little lean down low. The results are looking pretty good though to me. The little flat spot you have at 7K hz in your MAF table. I would manually smooth that out to the upper region.
    2000 Trans Am WS6
    Thanks for your responce, i will smooth out that area you pointed out. What had me concerned was how much i had to add down low and like you said its still lean.
    May 2011
    Tulsa
    45
    I looked it over and I just installed my alkycontrol. It is not in use. I have a 03 Z with 42lbs and a 3" Pully making 10lbs of boost. It is working good in all ranges and the miilage is beyond believe. Im using and AFX NGX wideband. How do I post my tune. I got yours and compared it. I have not added the timing in withthe alkycontrol yet. so this is just the charger adn a tune.. So do I have to email you my tune or im you my tune? I would like your input on it too.
    03 Z06 Magnacharger, Borla stingers with XP Stainless Headers,KB Boostpump, 42 lbs injectors, 160 stat. CAI3.TPS Motorsports 427 Shifter. AFX Powerdex wide band. TIC clutch master.Monster stage3 with 18 lbs flyweel. AFX wideband. 10LBS boost. ALKYCONTROL methanol injection. DTE Trans Brace, Built MN6, NGK Iridium 7IX , 2 Bar MAP.
    [email protected]
    www.haysauto.com
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    car looks good
    but its better to smoth your primary table ,,, numbers should increase with RPM and map
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    why does my ve table seem to be large (number wise) plus a loged it tonight with maf disabled and it seems the ve is still lean in the lower rpm areas. should i be looking for a vacume leak? this is a stock engine with a 112 maggie and a 90mm throttle body, does the numbers in my ve seem normal for a setup like this?
    Jun 2008
    Kuwait
    390
    i havent got experience for numbers ,, but the scanner can tell you everything if you are way high or low
    assuming you havent got any Vac leak ,,, if the car is lean then get it extra fuel ,, if all of your sensor are good then you have to trust them ,,
    Abdullah Al-najdi
    00965 99369929
    Aug 2006
    5BA8
    3,382
    VE is abnormally high in the lower regions. If it's not cammed, it could be right. Hard to say.
    The tune you posted isn't in SD, so if you're trying to tune the VE based on that tune, you're not.
    EFI specialist
    email=[email protected]
    The tune posted was with everything turned back on. this problem occured after i installed my 90mm j-tube and throttlebody. I also installed 60lb injectors and hope the IFR table is correct, i followed the precedure in tunning school book. I feel my problem is injector related but i dont know this for sure. thanks for all the help and advice
    Also this my by a dumb question but on the drive to work i noticed if i sit in gear with the brake on and move the throttle a can populate cell with very negative long terms, but do the same thing in park and the same negative long terms will start to lean up. So my question which should i belive is correct, or do i have something screwed up?
    Jun 2008
    Kuwait
    390
    what i beleive ,, by PArking ,, and putting the gear in 1 and the safety brake ON
    start increasing the RPM little ,,, and the car in the same place ,, that is a good way to do the Idle airflow
    Abdullah Al-najdi
    00965 99369929
    Iguess what i meant was i can drive to work loging maf vs LTFT , once i have my cells populated i can hold the brake and increase tps and watch the cells i hit go really negative LTFT's. Then put truck in park rev engine up slowly hitting same cells and watch the LTFT's lean back down. Is this normal? i dont know if im really rich or lean?
    I feel my ve table is abnormaly high in the low regions. only thing changed was throttlebody and injectors
    Jun 2008
    Kuwait
    390
    to be honest with you ,, i havent got experience to answer this question ,,
    but if you are going to to tune it ,,, disable the the DFCO
    so the numbers will be much clear ,, and the LTFT will be more stable
    otherwise every time you release the throttle ,, you will find change in the cells that you hit
    Abdullah Al-najdi
    00965 99369929
    Tuner smokestack's Avatar
    Jul 2011
    West terre haute Indiana
    111
    I Know there are alot of other threads and info on this. BUT this might help you out some. Tons of good info in this thread.
    http://www.hptuners.com/forum/showthread.php?t=36318
    May 2011
    Tulsa
    45
    Here is my tune. It idles good and pulls hard.Compare this to yours. I only have 42lbs injectors. See if this helps you any.
    [email protected]
    www.haysauto.com
    Jun 2006
    Western Pa.
    331
    What injectors do you have? Siemens 60's? What is the flow rating at 58psi?
    04 Sierra Denali,370,S485B, Built 4L80E, 3barOLSD, E85
    I got them from five-o-motorsports they are the plug &play which from what read are very hard to setup for a beginer tuner like myself. Im thinking about throwing in my 42lb maggie injectors in for now to see if i can get things in line.
    Feb 2006
    Canada
    1,963
    Don't swap them just yet. Someone here may be willing to share injector data that has the tables for those. Have you searched the Repository for data yet?
    http://www.hptuners.com/customers/tune.php
    2000 Trans Am WS6
    May 2011
    Tulsa
    45
    I got some tables that will do that from the tuning school and EFI Live.Let me know what you have like the guy said and the PSI. I have the 42 and I have not come close to needing bigger injectors yet. But Iam not cammed up however I was looking into the 90 mm TBI and new nose for mine. I will be more than happy to help with my knowledge. There are alot of guys on here that are way sharper than I am though. I want to see how the numbers compare on your truck vs the procharger one I showed you to see how they line up.
    [email protected]
    www.haysauto.com
