So I am helping a co-worker that has the following setp:
2001 5.3L with cable throttle
P59 from 2003 with the blue and green connectors
Running a XR269HR Comp Cams 269/273 .525/.532 114LSA
243 Heads
MAF sitting behind a cone filter and in a 4" Aluminum pipe
I have flashed in a 2003 Chevy Express 6L cal as it had the right HW IO's for the ECU and cable throttle. We are having an issue when we start it and try to idle. The engine wants to run up to 1500rpm or so and slowly walk up. I have made the following cal changes:
1) Made the P101 fail criteria 150 to get it out of the way
2) Set the rpm disable for VE to 200 to force it to run off the MAF
3) Told it it was a 800 (truck) platform
4) Changed cylinder discplacement to match 5.3 and said it was a 5.3L
5) Set fans up
6) Co-worker took some out of the VE surface at lower load/rpms
The issue we saw when we first fired it up was it would run at 1500-2000rpm. This was before I made it run off the MAF. Once it runs off the MAF, it will idle at 800 as is the desired idle speed, but then when the IAC closes (goes to 0), the engine speed goes up to 1500-2000rpm. We cannot figure out what is causing the engine speed to increase to such a high value?????? Different attempts have it idle at 800 for different amounts of time, then it will go up again. I know the Idle Airflow isn't properly set yet, but it is hard to do when I can't get it to idle at the desired idle speed.
I can post up the cal and log when I get home today, but was curious if anyone else has had this happen or know what to check.
Thanks,
Scott
3)
