Hey guys i need some help. I have been trying to tune for my injectors. I got the flow rate after doing the calculations on hp tuners. What else do i need to do? I have a 2000 camaro with a t3/t60-1 turbo all stock motor. Injector data is below and attached is my current tune.
Also if some one could make me a quick list of what is tuned first and last if it is not to much trouble.
(note) I have driven the car on a base tune but i know that is playing with fire and i need to learn how to do this the right way.
Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
Gain: 0.11ms/mg
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 600KPa
Series: DEKA 4 ( DEKA IV )
Orifice Type: Multi-orifice
Spray Pattern: 30 Degree Spray Cone
Factory fitted with Viton upper and lower o-rings
