Results 1 to 6 of 6
Thread: 3 Bar SD OS ?
    Dec 2005
    Texas
    254
    3 Bar SD OS ?
    Am I limited to the Low Octane timing table on a 3 Bar OS tune ? Do I still have to fail the MAF ? Thanks
    Dec 2006
    Fort Lauderdale
    171
    Quote Originally Posted by orange ss View Post
    You should still have the high octane table. Yes, always fail the maf manually by setting the maf fail to 0 and set the dtc's properly.
    2001 Z06 - Blown (Sold )
    Dec 2005
    Texas
    254
    I do have it, but didnt know if it was useable. Thanx for the clarification
    I count sheep in hex...
    Oct 2011
    36
    So...I can get a 2 BAR OS that retains the use of the MAF?
    2.5 Bar MAP - Speed Density (E38 ECM - LS2 and other engines)
    This enhancement contains the following features:
    2.5 bar (255 kPa) max MAP sensor support (calibration capability for GM 0-5V linear MAP sensors)
    Rescaled High MAF table supports up to 15400 Hz with 300 Hz resolution, also supports airflow up to 1024 g/sec
    New VE tables with 33 x 33 cell resolution each and configurable MAP and RPM axes (choose your own resolution)
    Charge Temperature based VE multiplier table, configurable axis
    TPS based VE multiplier table, 33 x 17 cells with configurable TPS and RPM axes
    MAP referenced "Boost Enrich" table
    Boost Enrich MAP threshold and hysteresis value
    Both MAF and Speed Density mode supported
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Do you have an E38 ECM or an LS1? LS1's have a 1 bar SD, 2 bar SD, 3 bar SD & 1 bar maf
