Results 1 to 13 of 13
Thread: NGK AFX Reading Question
    Nov 2007
    Minnesota
    555
    In my truck I'm getting a "stoich" reading of 14.4 to 14.50(rarely ever goes higher) on my wideband. Is this correct for the NGK AFX with ~E10 or should it still be reading 14.6 for stoich?
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    Nov 2007
    Minnesota
    555
    The AFX is compatible with fuels other than gasoline. The AFX’s display is designed to
    show AFR values based on a gasoline scale with 14.57:1 AFR as the stoichiometric ratio.
    The display will simply show AFR on a gasoline scale even though the fuel used may
    have different properties (stoichiometry for methanol is approximately 6.5:1). As long as
    you understand this, interpreting the values should be easy.
    This is where I'm confused. "on a gasoline scale"
    Since I'm not running pure gasoline(because of the ethanol), I shouldn't see stoich of 14.57 right? The wideband should be telling me the true air fuel.
    Feb 2006
    Canada
    1,963
    E10 is Stoich at 14.1 from what I found. A quote from Greg for you:
    "To work effectively with Ethanol blends, you really need to switch to units of Lambda to avoid confusion. (lambda = AFR/stoichAFR)
    Almost any hydrocarbon fuel makes peak torque somewhere near lambda=0.9. For pure gasoline this is an actaul AFR of (14.68)*(0.9)=13.2 AFR. With e10, it would be calculated based on lambda with a different stoich point: (14.13)*(0.9)=12.7 AFR. Both mixtures, although numerically different, look the same to the combustion process.
    e10 isn't a huge difference, but e85 get much more significant: (9.85 stoich)*(0.9)=8.9 AFR, which still looks the same as 13.2 with gasoline as far as the combustion process is concerned.
    Wideband sensors also don't know what %ethanol blend you're burning. The UEGO (wideband) sensor just measures oxygen percent and delivers a lambda number. The cheaper widebands just multiply this measured lambda by 14.6 to give unexperienced users a number they're used to seeing in magazines. Don't tune to AFRs (instead of lambda) using ethanol blends, it will only mislead you.
    Greg Banish"
    2000 Trans Am WS6
    Feb 2009
    277
    The ngk display should be showing 14.57 if you are at lambda 1.00 for whatever fuel you are burning.
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by MMGT1 View Post
    Greg Banish"
    Yep, but the wideband doesn't show lambda.
    Quote Originally Posted by superwagon View Post
    Shit...maybe a recal will fix it then. It's always reading richer than 14.57
    Nov 2007
    Minnesota
    555
    This guy has the same issue. His wideband is not outputting ON THE DISPLAY a reading of 14.57 for stoich:
    http://www.hptuners.com/forum/showpo...9&postcount=13
    Nov 2007
    Minnesota
    555
    Hopefully someone with the NGK AFX will chime in here and help me out...
    I can think of two problems here:
    1. My narrowbands are NOT putting me at stoich, hence such a rich reading at the wideband.
    2. The wideband is a piece of shit.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    The close loop PI control logic puts bias on the trims that leaves them on the rich side. I wouldn't sweat it. Make sure you have power and ground from your battery though.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Nov 2007
    Minnesota
    555
    guess i'll just roll with it then. thanks dude
    Sep 2008
    1,668
    The NGK seems to be one of the better "consumer" widebands I've used...I'd trust what it's saying...but like everyone else said, ignore the screen. Use the 5 volt output from the NGK, and tune to lambda numbers...that way you'll get the car dialed in regardless of fuel.
    Dec 2008
    on the Dyno
    1,825
    Also if you are getting a different afr on the wideband while in closed loop then modify your o2 switch points to help dial the closed loop stoich in. I do this alot so that customers wanting to stay in CL will actually get stoich.
    Located in Central Kentucky
    ShorTuning
    Nov 2007
    Minnesota
    555
    Not getting lambda = 1 in my logging either. Either my wideband is wrong or the narrowbands are switching too rich.
    Nov 2007
    Minnesota
    555
    Nevermind, it's all good.
