loaded the stock Z06 MAF table.
Do I need to tune this maf table accordingly with my mods (heads/cam), bolt ons? Or is set it and forget it type of deal?
Stock MAF, my maf freq was around 2600-2700 @ warm/hot idle and with this one its around 3K?
- Tuned
- 2K4 Z28
- 2K4 Tahoe
- 2K7 TBSS
If you changed a maf why not tune it to your car? every MAF has a sensor that may have a slight variance in difference. You posted heads/cam on your car but loaded a stock maf curve..... Sounds like you answered your own question here.. Go back and tune it.
Since you upgraded your MAF from stock to a replacement know stock value GM MAF you would copy paste the know stock values for the new MAF into your tune then tune from that starting point...no matter what you're mods are you are by no means done.
Janky Monkey Tuning
Call or PM for tuning solutions.
Cell 210-954-4985
Wrench turning provided by 2 Tightwads Racing.
Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
Still lost? Consult a Pro!
www.thetuningschool.com
www.calibratedsuccess.com
www.tunedbyfrost.com
GM made those stock tables on a flow bench with the factory air ducting connected all the way to the throttle body and intake. Putting a Z06 MAF curve will get you in the ball park simply because it's the same sensor but the intake ducting on a vette is completely different than that of a fbody and you listed mods like camshaft and cylinder heads which will also change how the airflow passes through the MAF. So your best bet is to tune the MAF for you combo to make sure it is correct.
James Short - [email protected]
Located in Central Kentucky
ShorTuning
Thanks fellas. Just needed the confirmation.
- Tuned
- 2K4 Z28
- 2K4 Tahoe
- 2K7 TBSS
Agreed with above....
01 SS Red A4 #4987
