As suggested I'm posting this tune. Not my work as I was not really familiar with tuning at the time this tune was done(which was a while ago). I'm still learning and have been going through the board, using gregs dvd, and tuning school material to help broaden my knowledge. Before this tune I had a predator tune which was a custom one due to the camshaft but the car felt so much better with that tune.
Mods:
TR224 (112)
QTP 1 3/4 LTs
Magnaflow Catback
LS6 Intake
Lid
Green Top Injectors
Pulleys
Racetronix Pump
125hp HSW Plate(Setup but never used yet because car didnt feel right)
9in with 3.90s
Dynojet w/b
So when I had it dyno tuned they strapped it down and went for a base line. Injectors were at about 95% dc so they suggested injectors. I said ok and they said the green tops were the way to go.
Lets start with the idle, cold idle is really bad (surging and rolling). Once its warm idle is smooth but the car really stinks. A few things I noticed was that none of the injector data except the flow rate were changed and the ve table has a weird ridge at the lower rpm range.
The car feels very unresponsive compared to what it felt like when the predator tune was in. Throttle response is very soft and wot is not what it was before. I know the butt meter isnt a good guage but the whole overall attitude of the car is off. I noticed that the ve table (with the exception of the low rpm area) is virtually unchanged from stock. Unfortunately I didnt pull the predator tune out before I had this done so I cant compare to that but when compared to stock the ve appears to be almost identical.
I was told the only change I would need to make if I wanted to run nitrous was to pull 4 degrees out of the timing table in the wot areas.
I'm already working on an updated tune with the injectors setup correctly using gregs dvds as a guide. Not sure if just doing that will solve my idle problem but I feel I cant go any further till I get that right. Any suggestions would be greatly appreciated. I dont have access to a dyno but I think I'm correct in assuming that even with this small cam the ve has got to be changed. Is it realistic to think I can get a good ve on the street without a dyno? I miss the snappy feel this car once had...
Once I get the driveability is straightened out Ill deal with WOT. Thanks in advance for the help.
