Results 1 to 15 of 15
Thread: Stall torque management question.
    Jan 2012
    33
    I am having a difficult time understanding what this does, and how changes affect the transmission. Can someone assist and clear this up for me? Thanks so much.
    Jul 2011
    Pasadena, TX
    39
    xx2
    Jan 2012
    33
    Anyone?
    Tuner sjgrimsley's Avatar
    Jul 2011
    NW Louisiana
    66
    Bump. Also interested.
    2008 Crystal Red Metallic Base Coupe A6 FE1. FlexFuel conversion, 418 LS3, CamMotion 230/234 117+0 cam, 11.5:1 CR, full Z06 exhaust, custom cold air box built around stock Z06 air bridge. Running Amsoil Signature Series 10w-30 and Amsoil Signature Series Fuel Efficient Synthetic ATF. Tuned by me with AEM 30-0333 WB thru HP Tuners.
    +231,XXX miles as of 12/12/19.
    Grimsley Performance, LLC on Facebook
    Grimsley Performance uses Amsoil
    Tuner carneb's Avatar
    Apr 2006
    Sydney, Australia
    101
    If it's the one I'm thinking of (just has an enable rpm and disable rpm) its only there to prevent you revving the engine with your foot on the brake.
    VE Calais V 6.0L L98 V8 6L80E
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    Match it to your converter stall speed so you dont set a code.
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
    Feb 2006
    Rancho Santa Margarita, CA
    905
    I have mine maxed out and i see no codes, it's the only thing in my tune i really have no idea how it works , i maxed it out by mistake though, at least 6 months ago. Never felt anything abnormal because of it.
    Oct 2011
    25
    Has anyone happened to figure out what this actually does yet?
    Nov 2012
    27
    I'm also curious what the difference is between brake torque management and stall torque management. Is brake torque management and stall torque management disabled when you press the traction control button to off?
    Nov 2012
    27
    I noticed that my stock tune had the brake torque management disabled and stall torque management enabled (2000 rpm enable and 1600 rpm disable) and I don't remember being able to stall up the converter higher than 2000 rpm even with the traction control button turned off.
    Dec 2006
    Pensacola, FL
    489
    Does the same thing apply to the A6's?
    Jun 2011
    Montreal, Canada
    758
    I have it maxed out on my A6. Never had an issue because of it. I believe, as stated, it limits the rpm when the brake is applied.
    2007 Corvette C6 Vert. A6
    LME LS402, Pat G custom cam, ATI 10% OD Damper
    Circle D triple disc 2600, 3.42 Diff
    YSI, 3.0 pulley, ID 1000's
    Alky Control Meth,
    ARH 1 7/8 headers,
    1009 RWHP @ 7000, 817 RWT @ 6000
    Nov 2012
    27
    I'm curious what limits the rpm. Is it spark, fuel, or ETC?
    Nov 2012
    27
    Just noticed ETC stayed at 33% when I had my foot to the floor so I'd like to figure out how to switch it to spark.
    Tuner 00GrcyGtr's Avatar
    Jul 2016
    Westfield, IN (Suburb if Indy)
    169
    I just happened across this really old thread whilst in a search and am surprised this question never did get a real answer.
    Does anyone know the answer to this? Anyone? Hello?........................
    __________________________________________________ __________________________________________________ __________________________________________________
    "To explain the lure of speed you would have to explain human nature; but it is easier understood than explained...Speed is the second oldest animal craving in our nature..." -- T. E. Lawrence
    2000 Regal GSE
    2007 Trailblazer SS
