Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Zr1 flat foot shifting tables?
  1. #21
    Dec 2008
    on the Dyno
    1,825
    If you make Spark the only rev control method trust me it will make fireballs haha. If you don't want fire but want that lazy throttle closing feel between gears gone then disable ETC and keep Fuel Cut enabled.
    Here's some fireballs for ya!!!
    http://youtu.be/VODpzrTZafg
    Located in Central Kentucky
    ShorTuning
  2. #22
    Feb 2006
    245
    Quote Originally Posted by LSxpwrdZ View Post
    what would the best setup to keep turbos spooled during shifts?
    [IMG][/IMG]
  3. #23
    Bump for the above question, and that is one sexy picture!
    Owner/Tuner Street Performance Syndicate
    06 GTO: D1SC , Full Suspension, 23X .6xx lift Ed Curtis Cam, Mast Heads, Gforce 9" 4.11 Gears, Holley High Rise, Stage 12 Fuel System, Boost By Gear
    01 Duramax: Blown Tranny (again) BWs467 Turbo, Head Studs, Exergy Injectors, Lift Pump, Moonshine
    2014 Taurus SHO: (Wife's Car) OR DPs, Tuned, CAI
    2006 TBSS; AWD SLP Catback, K&N CAI, Tuned
  4. #24
    Dec 2008
    on the Dyno
    1,825
    Spark only will help keep turbo's spooled between shifts mainly because the raw gas combusts in the exhaust manifolds releasing pressure that spools the turbos. Ideally you would want to retard ignition timing as well so that when spark does fire on the limiter it fires late aiding the combustion in the exhaust. However without some sort of ignition retard box I'm not positive on how to achieve that.
    ShorTuning
  5. #25
    Feb 2007
    Calgary
    155
    Quote Originally Posted by NICKY BOY View Post
    whose car is that ??
  6. #26
    Aug 2006
    Cape Coral, FL
    99
    looks awesome
  7. #27
    the Spark option retards the timing, it doesn't cut the spark.
    I count sheep in hex...
  8. #28
    Advanced Tuner Bluecat's Avatar
    May 2006
    Catlettsburg, Ky
    407
    Quote Originally Posted by Chris@HPTuners View Post
    Thank you. And not a very viable option on bigger power / FI cars, as even with heavily negative timing some cars will still have enough ass to continue to rev. So in some situations setting limiter to spark only, you may not have any rev limiter at all. So use that option with caution unless you want to chance tagging 9K on a missed shift.
  9. #29
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Chris, I know this is a long shot so forgive my ignorance with this question. Is there any chance to be able to apply a SPARK CUT feature to the tunes, that way our ECM can perform on its own to be a 2-step? That would be ridiculously cool!
    618/618 motor
    906/862 spray
  10. #30
    Dec 2008
    on the Dyno
    1,825
    Very interesting! There is an extreme rpm cutoff setting in most OS's as well that overrides everything or at least is supposed to in this case. I normally set it a couple hundred rpm above the normal rev limit. Chris clarify that for me if I'm wrong.
    ShorTuning
  11. #31
    Tuner 01 MidMet WS6's Avatar
    Jun 2007
    St Paul, MN
    168
    Is this on a gen3 ECU? If so are you using the P/N limiter table to get it to 2 step?
    01 WS6-M6, PRC Stage 2.5 5.3's, MS4, Kooks 1 3/4", custom built full true duals w/ X-pipe, SLP lid, tuned via HPTuners
