Results 1 to 2 of 2
Thread: speedo correction after gear change
    have an 08 gt shelby with new gears. stock size tire and wheel. when i open up the speedo tab i can change the final drive ratio. ok that was easy. but the speedo doesn't change much or at all.
    there are a couple things i am not sure about.
    1; "use vid" enable/disable. should i select disable?
    2; "n/v base" do i use algebra to figure out the new value? or do i leave it alone? or?
    thanks
    28,264
