Im helping a friend of mine with his 03 Z and the issue is when rolling you clutch in the RPM will hunt and surge. At times the car will die. If you throw it into neutral real fast it will settle down quickly and the idle will stabilize. When the car is not rolling there is zero issue with the idle. It will instantly fall right into the commanded 950 RPM.
The car is a 441ci with ported LS7 heads and a 248/256 cam. The issue showed its ugly head when he swapped from 1 3/4 headers to 1 7/8 and also at the same time going from a Spec twin disk to a Ram that was a little bit lighter.
attached is the tune. Advice would be appreciated
