Well guys the car is really starting to tick me off. I just got the katech ls9x clutch put in and im putting the breakin miles on it and trying to get the kinks worked out in the tune. The car ran absolutely perfect before the clutch but ever since it has gone in she has been giving me troubles(lightweight flywheel). Ive completely redone the minimum airflow table to get it where it atleast won't cutoff or surge uncontrollable when I push the clutch.
Now im also having the dreaded 1700 and below bucking at light load. Before the clutch didn't have any problem cruising at 1400 now unless im in the gas its a bucking bronco. Ive tried lowering the timing in the areas it does it and raising to no avail can anyone help me out. Thoughts ideas anything. Thanks guys.
