Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Help me diagnose this KR
    Feb 2006
    Rancho Santa Margarita, CA
    905
    The car is a G8GT with Kooks 1 7/8 Mid lenght headers, hi flow cats, stock CB with mufflers and x pipe, and Rotofab CAI, Cali 91 Octane gas.
    The KR at WOT past 5000rpm is driving me crazy , question is why this damn engine cannot take more than 18* at 5200rpm or 20* at 5600rpm. i have a tune that basically command 16-19* in the same area and of course KR is not an issue. once i up the timing, (16-19* seems fairly low), the KR starts.
    I'm attaching a log from this morning, 3rd gear pull with a shift into 4th to observe the KR in the problematic cells. also the config file since i'm also logging KR per cylinder.
    The timing is still low at 19-20*, fuel at about .84-.86 lambda, she shouldn't show KR, so what that hell is going with this heap ?
    Car runs good with less timing, but again, 16-19* in those areas sounds fairly low.
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    I did notice the MAF drop 10-12% right as it senses the knock retard, and you O2mv drop a tiny bit from .890 to .870
    That would lead me to think if the MAF is dropping in hz, that your O2's would get richer not leaner. One thing that could cause them to go down in a case like that would be misfire. Maybe do another log and add the misfire by cylinder to see if thats the case, and then you will know what cylinder is causing it. It is on bank one, as bank two mv dont drop quite the way bank 1 does. Hope this gives you something to look at anyways and or a way to trace where its coming from.
    If you do narrow it down to one cylinder, put a new plug in it and relog, if thats not it, then swap one thing at a time to another cylinder and then relog to see if it jumps cylinders. EX: wire, then injector.
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
    Feb 2006
    905
    Thanks for the suggestion. I'll add the misfire per cyl pid's and total misfire to the scanner to check that route.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Looks false to me, like vibration induced. I run 19-21 degrees, with forced induction, on 93 octane. 10.8:1 Compression.
    Check the mechanical factors around the knock sensors.
    618/618 motor
    906/862 spray
    Feb 2006
    905
    Tested a 3rd WOT run this morning, slightly going up hill this time, and there are no missfires at WOT. Surprisingly, the KR was less this morning, even going up hill.
    Feb 2006
    905
    Quote Originally Posted by IDRIVEAG8GT View Post
    Where are the knock sensors located ? Do you have a pic or diagram link i can check ?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Are you sure it isn't just a bad tank of gas? I've had cars with 93 octane from QuikTrip that knock their ass off and timing ends up about 10* lower than it should. As soon as they get 93 octane from a good gas station (like Shell, BP, or Mobil), all the timing comes back no problem.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Feb 2006
    905
    I've tried different gas stations with the same results, another problem is that i can't find 93 at the pump around here, dang Southern Cali
    I can mix 100 octane gas to come up with 93-94 octane,but 100 octane is around 10$/gallon.
    I have no issues with E85 for example, i can bump the timing to 23-24* in the same areas without KR, but i don't understand why the engine would show KR with only 19* and 91 octane.
    I've tried going super rich (.78 - .80 lambda) as a test, and the KR is still there.
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by bluegoat06 View Post
    Hehe, they're on the bottom (sides) of your block. The headers primary pipes run right by them.
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,860
    Try a slightly colder plug.
    Feb 2006
    905
    Did that already, went from stockers to TR6, ran them for like 20k miles, and now i'm back to the stock heat range with TR5's.
    Something i've noticed is that the KR is a lot less when the temp outside is cold like it was today today (50F), with cold IAT's (today at 55-58F IAT) i won't see those 3* KR, it was 1* max, same gas in the tank, in the afternoon with 70F+ (76-80IAT) outside, guaranteed 3* KR by 5200-5600rpm with the timing i currently have in the file i posted.
    I can add timing to the IAT modifier and put it back to stock (I zeroed the 86-95F rows), but still, i can't believe this sucker won't take more than 18* at 5200rpm. it's pretty much a stock engine with little exhaust done. dang it.
    Feb 2006
    905
    Silly question, but since i've never seeing a knock sensor in person, i'd rather ask , what do they look like ? are they bolted outside of the engine ?
    Mar 2008
    St. Louis, MO
    4,860
    Stock manifolds don't give much room for timing to be added up top. Can't say I'm shocked.
    Feb 2006
    905
    That's another thing, she doesn't have stock manifolds, they're kooks 1 7/8 mid lenght headers with cats. They're not LT's, but they're not as small as the stock manifolds. Oh well, will see, i made a little adjustment to the 9.3-10k HZ using your MAF smoothing tool. I'll give it a try and see what happens although it's cold again tonight so i'm not expecting to see the same KR as last Friday.
    Maybe i'll use the exercise as an excuse to get the LT's
    Tuner Mez's Avatar
    Nov 2008
    Austin, Texas
    163
    Something i've noticed is that the KR is a lot less when the temp outside is cold like it was today today (50F), with cold IAT's (today at 55-58F IAT) i won't see those 3* KR, it was 1* max, same gas in the tank, in the afternoon with 70*+ (76-80IAT) outside, guaranteed 3* KR by 5200-5600rpm with the timing i currently have in the file i posted.
    I would not necessarily worry about the amount of timing it takes if it makes the HP it should. Some people believe the more ignition advance, the more HP. This is true only to a certain point. Some motors I've seen make more power with less advance. Give it what it wants. The LS engines do not require a lot of advance.
    For my mods, I ended up at around 20° over 5800 rpm. Before I installed the FAST 92 intake, the stock intake made max power 26°. But I picked up 31 rwhp with the FAST and it needed less advance. Why? The denser the air in the combustion chamber, the less advance needed. How else would it make more power?
    Another thing I've been experimenting with is the IAT table. The stock table is pretty good. I read all the time about guys zero'ing out the table below 131° because they don't want the computer pulling timing. Bull hockey. The IAT table is there to match the advance to what the engine needs. Now that the air temp has dropped to ~65° in Texas, I noticed it can take more advance without knocking.
    Less advance is needed because the flame front travels faster as the combustion chamber heats up. If you zero out the IAT table below 131° like I've seen done by some tuners, you are not matching the advance to what the engine can use when it cools down. What I have seen work on my engine is set the high-octane table to what makes the most power in the cooler air then let the IAT table take away timing as the air heats up to prevent knock.
    2014 Corvette, Z51, 3LT, 7-Speed, NPP, 2 tops, Exposed Carbon Fiber roof, FAY, Laguna Blue, Kalahari, Museum Delivery.
    Sep 2011
    Germantown WI
    414
    Its frustrating for sure, but since its worse when warmer out, its real knock. Mine is the opposite, running 28 degrees above 5200rpm, but I have knock issues in the midrange, like from 3200-4800rpm. Can only run 19 degrees there. In the process of porting my stock manifolds now (hey its free), hope to see a tenth or two and be able to add more timing.
    Mar 2008
    St. Louis, MO
    4,860
    Ah, for some reason I totally overlooked the mid lengths you listed.
    Aug 2010
    Roswell, N.M.
    1,956
    Yeah dude, they're bolted on. Sides of the block, directly in the center. They're either a yellow/tan or black. Round units with a single two/three wire plug.
    I see stock internal G8's with headers dinking around with 22-24degrees up top. So idk?
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Mez View Post
    In a nutshell, this is right on.
    618/618 motor
    906/862 spray
    Feb 2006
    905
    Gave it a try yesterday, and even at .82 lambda, the engine rattled with only 20* at 5100rpm or so. i backed the timing down to 17-18* and is all good again. So that KR in my logs is not fake, i could hear it too. Damn it.
    Makes me wonder if the cats are starting to get plugged ? what other mechanical conditions can induce knock ?
    Car runs good otherwise with less timing, i'm behind .1-.2 sec slower than other G8's with LT's and CAI at the same track, but damn it, i can't believe i need to run baby timing when a lot of other G8's seems to do fine with 20-23* in the same area.
