guys,
I've added a few new parameters for T43 TCMs (6 spd auto trans).
Clutch Air Purge - allows you to disbale the clutch air purge feature on startup
Skip Shift via neutral - allows you to disable all skip shifts via neutral, forcing the trans to shift each gear sequentially
Skip Downshift via neutral - allows you to disable all skip downshifts via neutral, forcing the trans to downshift each gear sequentially
The clutch air purge was requested by trans builders who are getting startup clunking problems after fitting aftermarket clutches. I'm not sure if there willl be any detrimental effects of disabling this, but the clunking will be gone.
The skip shift disables are useful for preventing neutral engine flare shift lockouts on shifts such as 4-2. This is when you have disabled torque management (or have it really low) so that the engine flares badly on a neutral skip power downshift. If this happens the trans will just sit in neutral on the rev limiter until you let off the gas, then it will slam (and i mean slam) into the lower gear. Not nice. These values allow you to force the trans to shift 4-3-2, rather than the 4-2 skip.
Chris...
