Help ETC dies on me
Hello, I am having a DBW issue...
I installed an ECM and harness from an 03 Escalade onto a Rockcrawler Jeep, the original ETC pedal and TAC did not work, I used another Pedal and TAC and it worked but only for a few seconds.
The engine starts and responds to the pedal correctly, but then after a few "pumps" of the pedal it stops responding. I turn off the ignition and the cycle repeats, it responds for a few seconds and dies again...
Any ideas?
By the nway I did use the search button and found not much...
I was told on LS1Tech that the TAC and pedal have to match the ECM, is there a way to relink what I already have, or how do I know where the TAC came from so that I can refglash that OS onto the ECM?
It almost feels as if the ECM were cutting them off, can it be the throttle body assy?
I also have a couple of these, It does not hurt to test it while I get more light in this matter
Tanks again
Rat Chevelle
