Trying to read the VCM on a 2009 F-150 5.4l and keep getting the error "IGNITION CYCLE TIMED OUT" can anyone help?
That is an ECM/TCM that hptuners does not support and it is totally different than the 2008 F150 PCM
Ryan
I have the same problem with a 2006 f-150 fx4 5.4l auto trans. error pops up ignition cycle timed out. any help would be great. thanks
Are you closing the ignition switch then opening it again when prompted?
If there anything like some of our Aussie Fords then battery voltage goes a long way to solving alot of the problems.
Silverado 2001 4wd rcsb, LS 6.6L, Edelbrock Super Vic manifold, Aarons 102mm elbow, Wilson 105mm TB, AEM dual Nozzle water/meth kit, 60 psi injectors, Automotive FPR, dual Walbro Fuel pump setup, compcam 230/234-.572-.576-114, WCCH Stage 2 heads, Front Mount Turbo MP45R Turbo, Intercooler , dual 3" maganflows, no Cats, CKPerformance Billet 4L80E, ProTorque converter, 14 bolt Detroit TrueTrac 3.73.
Camaro 69 SS Mast LSX454, FLT 4L60E.
Silverado 2009 Hybrid 4wd Waiting for HPTUNERS
Yeah ford went to a new pcm mid 2009, the newest beta should be able to read them though
