Results 21 to 40 of 49
Thread: Virtual VE Tuning questions......
  1. #21
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by SargeZ06 View Post
    Some where I came up with .618 and 10.42 for mine. Is that wrong?
    For lambda reading in the scanner the function is 1/10.407 + .618
    The resolution on the divisor isn't great so I use the List to describe the voltage to lambda output.
    Located in Central Kentucky
    ShorTuning
  2. #22
    I was told, in a one word response, "NO" by Bill via an email when I asked him this question.
    That makes no sense at all since the earlier versions of 2.23 beta had this in it. They didn't have the system like bluecat, but the software showed the calculated v.e. table. They for some reason removed that and I've been waiting since for it to come back.
  3. #23
    Jul 2008
    Louisville, KY
    417
    Quote Originally Posted by zippy performance View Post
    Well maybe Bill can comment but that is what he told me earlier this year.
    Sarge
  4. #24
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    I dont know why they couldnt just use a blank LS2 VE table in there so you can copy and paste numbers into - then youd have access to the smooth feature, multiply by % functions etc. Seems like this is already created, wouldnt take anything to add it????? Come on guys, make this happen!! Maybe if we all PM them about it?
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
  5. #25
    Quote Originally Posted by LSxpwrdZ View Post
    That's basically what HPT's "Custom OS" is, all it does is incorporate the tool into the program...
    I thought the custom OS overwrites the code for that part of the operating system with a traditional VE look up table.
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
  6. #26
    Dec 2005
    Sydney Australia
    510
    Quote Originally Posted by turboffr View Post
    Getting ready to install a cam in my '08 vette, and would like to be able to tune the Virtual VE tables. Can someone confirm if my basic understanding of the tuning process is correct using Bluecat's VE program?
    1.) Copy VE equations from my tune into the software to build a VE table
    2.) Force MAF off in the tune
    3.) Force open loop
    4.) Scan AFR % error (commanded vs. actual -Wideband) in histogram (VeLoAltd table) where MAP is column headers and RPM area row headers.
    5.) Adjust virtual VE table in the program by the error % observed in the histogram, save table.
    6.) Load VE equations into tune from software
    Assuming the steps I have outlined are correct, could I also use fuel trims in closed loop to tune the VE table in step 4?. I have 10% ethanol fuel in my area so when I tune the lower rpm/MAF ranges in open loop the wideband the trims are always correcting. If I changed stoich to 14.2 would open loop with the wideband be the preferred option? I've heard the o2's are pretty accurate in idle and part throttle.
    Thanks.
    do youself a favour and forget the VVE shit...
    just apply the 2 bar OS and set the MAP sensor valves back to stock under the engine diag tab,
    rescale the VE table back to 105KPA and tune it like a normal car..
    put some numbers in there from a LS2 VE table and get started, no messing around and save your self a heap of time..
  7. #27
    Quote Originally Posted by VYSSLS1 View Post
    Amen!
    If you have the tools, might as well use them. If you don't have the enhanced OS available then no harm using the factory OS as it is more than capable, but the Enh OS is pretty handy.
  8. #28
    Dec 2005
    Sydney Australia
    510
    enhanced OS is avaliable for corvette OS's, so no reason not to use it...
  9. #29
    Oct 2009
    Massachusetts
    183
    not sure I follow you on how to apply the 2 bar OS.......
    2002 EB C5Z06. ECS Novi, Alky control meth & headers, 633 rwhp
  10. #30
    Dec 2008
    on the Dyno
    1,825
    Quote Originally Posted by Xjas View Post
    May be speculating on this but I would imagine the VE lookup table you see just modifies the coefficients to reflect the VE you are seeing. It would take alot of coding to rewrite each OS to take out the virtual VE and replace it with just an older version of GMVE with a table.
    ShorTuning
  11. #31
    Oct 2009
    Massachusetts
    183
    I'm all set. Used the Bluecat program and it was quite simple actually. Car is running good with the new cam. Thank you everyone for your input
  12. #32
    Dec 2005
    Sydney Australia
    510
    you are incorrect,
    the Custom OS acutally removes all the coefficients and replaces them with a full VE table,
  13. #33
    Dec 2005
    Sydney Australia
    510
    click on the OS tab at the top, then vcm enhacments, then click on the 2 bar os and follow the prompts,
    the create your ve table, then write entire back to the PCM and your done...
  14. #34
    this is what i do , only issue is you cant do it on any 09 and newer pcm that i am aware of
    Owner of Cunningham Motorsports
    06 z06
    2016 camaro
    68 Camaro
    2014 e63 amg
    07 LBZ Duramax
  15. #35
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,301
    Quote Originally Posted by rynez06 View Post
    Why not? We offer custom operating systems all the way through 2012's last I checked.
  16. #36
    really?? everytime i look at the custom OS tab it says unavailable, i believe i have the newest beta from you.... if so i would love to get it, i have a 2010 TT car here that i would put in 2.5 bar os
    06 z06
    2016 camaro
    68 Camaro
    2014 e63 amg
    07 LBZ Duramax
  17. #37
    ok i just looked at a few of 2010/11 camaro tunes half of them dont allow me to right it as a 2 bar os, other half do.... and no 2009+ vette files do
    06 z06
    2016 camaro
    68 Camaro
    2014 e63 amg
    07 LBZ Duramax
  18. #38
    HP Tuners Support
    (foff667)
    28,301
    2012 Corvette 12647991 has 2 bar
    2011 Corvette 12639270 has 2 bar
    2010 Corvette 12635863 has 2 bar
    2009 Corvette 12628990 has 2 bar
    2008 Corvette 12617631 has 2 bar
    2007 Corvette 12614676 has 2 bar
    2006 Corvette 12605732 has 2 bar
    2011 Camaro 12639270 has 2 bar
    2010 Camaro 12633056 has 2 bar
    2010 Camaro 12635863 has 2 bar
  19. #39
    is there a way to get a 2 bar OS other OS's that arent listed ?
    for example os ID 12628988 (09 c6 z) and os ID 12637084 (2010 camaro SS m6)
    06 z06
    2016 camaro
    68 Camaro
    2014 e63 amg
    07 LBZ Duramax
  20. #40
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    Get the car Tech-II'd to the latest OS... If you have unlimited licensing, just grab a file that has the OS available and start with that. Just change the VIN.
    http://www.dsxtuning.com
    Just say no to bull s***.
