very weird happenings today. Had to work on two Hummers H2, both with maggies, both 2005's, on both tuning for Maggies was done as usual and the first one was done within a few hours and drives and runs great.
The second one took an awful long 20 minutes to do a read entire, I copied calibration parameters from first over and wanted to write calibration. No luck, no way to connect to PCM. All tricks tried like 20 minutes wait, PCM fuses pulled, NAV/Radio fuses pulled and so on - no way. Tried to flash stock file into it via Tech2 - same, no way to connect.
took a spare 2005 PCM, installed it, flashed stock calibration over it with Tech2, did a read entire, made changes to it as needed for the Maggie, did a write calibration and car starts and runs. OK we thought.............put it into gear drive 10 meters and it stalls and never ever I am able to connect to it.
same as above !!
WTF happened please?
