Finally I've applied 3 bar OS, put some ballpark numbers in VE table and drove a bit. Immediately I've noticed that at the same load it shows some 7-9 KPa higher than I saw with stock MAP, also the car runs richer. My MAP offset is 10KPA (default). Before I was cruising at about 40KPa and idling at 42KPa, now 46 and 48KPa. Maybe I should bring this offset down to some 4-5KPa? I've tried a bit with offset = 4KPA and it seems to run a bit lean but closer to where it was.
