Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Torque Management Advance
    Tuner in Training the1n_only's Avatar
    May 2010
    Belton, TX
    29
    Ive been chasing my tail with this one. I have noticed it on a few cars now and on mine it is pulling as much as -25 degrees of timing causing the car to buck. I have all torque management tuned out and it keeps pulling timing. Can someone assist? Thank you.
    2006 DSOM Vert LSX451ci 602rwhp / 551rwtq
    2010 CGM Chevy Camaro 2SS Stock
    2011 Black GMC Denali HD Stock
    Aug 2006
    5BA8
    3,253
    Data log and a tune would help.
    EFI specialist
    email=[email protected]
    May 2010
    Belton, TX
    29
    The tune is all I have, I am currently on a business trip until the 29th. If you can take a look and see if you spot anything that could cause torque management advance to pull timing that would be great. Thanks in advance
    Here is a run down of the car...
    451 CI 4.185 bore 4.100 stroke
    12:1 static compression
    257/266 .649/.637 112+4
    1.7 Terra Yella
    TFS 245 68cc heads .040 cometic's
    ported 102 fast and NW TB
    FAST 57lb injectors
    Electric water pump
    ATI 10% underdrive pulley
    American Racing 1 7/8 headers no CATs
    Z06 B&B Bullets
    Halltech Superbee intake / converted to LS7 MAF
    RPS BC2 clutch - steel flywheel
    3.42 gears
    Aug 2006
    5BA8
    3,253
    If you don't have a data log, I need a better description of what it's doing. "Pulling timing causing buck" doesn't cut it. When? What is exactly going on, and what does it feel like? What are the driving conditions?
    EFI specialist
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    I assume you're talking about low rpm light throttle cruising. Pull timing from the main spark table. I run cars at 22-25* below 1800 and 0.40 g/cyl to get big cams to calm down.
    http://www.dsxtuning.com
    Just say no to bull s***.
    May 2010
    Belton, TX
    29
    DSteck I do get some light part throttle surge, but I found it surged worse running that the timing around that point. I bumped the timing up and it cleaned it up considerably. Where I see the torque management advance kick in and pull timing is on throttle tip in. For example changing from first to second or second to third gear during a light cruse situation. You also sometimes see it in 5th and 6th gear light throttle it will pull at time 5 to 6 degrees of timing. At first i thought it was burst knock pulling timing, which it does for a briefly like it should but I also noticed something else was pulling timing. I set up my scanner to log all timing PIDs and low and behold that was causing the huge timing dips and bucking. I can push the clutch in and right back out and it goes away. I wish I could get post a scan.
    edcmat-l1 and Dsteck This is my first car Ive tuned. I had a big name shop tune it and paid 500 for a sub par tune that you could barley drive on the street because of the bucking, poor fuel mileage, Some times it would start some times it wouldn't. I could go on and on about the things that was hacked and i've managed to correct. If you can take a look and provide some constructive criticism from two well respected tuners it would be greatly appreciated.
    Mar 2010
    Texas Hill Country
    3,299
    turn off tc and stabilitrack and see if it still pulls, make sure you have all -1.00 in the multiplier table under Trans - TM - table at the bottom right
    when i tune the timing map i do this and it doesn't pull any timing so i can see what's really going on at the motor.
    Dec 2009
    Slave Ship
    199
    I'm having the same problem right now with an 06 Z06 with an almost identical setup. Torque management is juggling timing in the 1400-1800 rpm cruise area causing it to buck.
    Mar 2008
    St. Louis, MO
    4,860
    Those timing dips aren't the cause. Disable M6 spark smoothing. The spikes will go away but it will still buck.
    Dec 2009
    Slave Ship
    199
    I was under the impression that M6 spark smoothing made the transition from coastdown spark to main spark/idle spark table not quite as abrupt. Is this not the case?
    And why do you say the bucking wont go away? The only time the car bucks is when the spark gets juggled like that. I've taken timing out of those areas to try and calm it down but everytime that TqMgmt advance shows itself, the car starts bucking.
    May 2010
    Belton, TX
    29
    Quote Originally Posted by Nodnarb View Post
    That is exactly what mine does.
    Mar 2008
    St. Louis, MO
    4,860
    It's an effect, not a cause.
    Dec 2009
    Slave Ship
    199
    Care to elaborate?
    BTW, my tune has been scaled by 25% I don't know if that throws anything out of whack.
    Mar 2008
    St. Louis, MO
    4,860
    Just try it. Disable M6 spark smoothing and tell me what happens.
    May 2010
    Belton, TX
    29
    I wonder just how much my FAST injectors are amplifying things. All they are is re-drilled LS2 injectors and not having the correct injector data. Ive been looking hard at the ID1000 for when I switch over to E85 and more compression.
    May 2010
    Belton, TX
    29
    Quote Originally Posted by Higgs Boson View Post
    Im not sure what table you are referencing here. Keep in mind this is a 6 speed car not an auto.
    May 2010
    Belton, TX
    29
    What effect does the "minimum final spark" and does it play a roll in torque management advance?
    Dec 2009
    Slave Ship
    199
    My car is out of my hands for a while. the1n_only, can you try this and report back?
    So if it is M6 spark smoothing causing those dips, where is it getting the values to apply?
    May 2010
    Belton, TX
    29
    Nodarb, I will give it a try but I don't get back into town from my business trip until Saturday evening. But im with you, where is the source of the values causing the timing pull.
    Dec 2009
    Slave Ship
    199
    Sounds good. I won't have the car back for several weeks.
