When the VCM Scanner is connected the VCM Editor gives an "The interface was not found." error. To remedy this you need to go back into the VM Scanner and disconnect the interface, unplug/re-plug in the USB port or close the Scanner.
It would be nice if the VCM Editor recognized that it was the Scanner that had the port and disconnected it. May with a prompt or warning dialog box.
