What do you mean go back to 26# injector settings? Did you get new injectors? You need the proper data for what ever injector you have. You have fallen prey to the idea you can steal data from a corvette file and make it work for your mods. It does not work that way, you cannot cheat in this manner. If you had put in a stock z06 engine you may have been fine. But cam, headers, and intake are all going to change the values from stock anything. Now it you put z06 injectors in, that is the only data you can copy straight accross.
You can dial in your low and mid speed ranges using fuel trims, but WOT can only be done with a wideband. I suggest you buy the wideband and tune the whole setup that way, its easiar. Your maf curve and ve table need to be reworked to match your engine.
Here is a link to lt1bird guide. Read through it and understand it. Get a wideband(plenty of writeups on here to guide you to which one is best for you). If you have any questions along the way, ask. Plenty on here that have done it.
http://ls1tuningguide.com/tuninghelpfiles.php
