Would anyone have any data, (flow rate, Offset vs Volts vs Vac) for Trick flow TFS-89880 80 lb injectors???
They are rated the same as the Siemens 80 lb injectors in "04redline/omega's" excel spreadsheet. Would these figures be "close enough", or should I track down the real numbers???
