Results 1 to 2 of 2
Thread: Trick Flow 80 lb injectors, any data???
    Oct 2008
    Australia
    63
    Would anyone have any data, (flow rate, Offset vs Volts vs Vac) for Trick flow TFS-89880 80 lb injectors???
    They are rated the same as the Siemens 80 lb injectors in "04redline/omega's" excel spreadsheet. Would these figures be "close enough", or should I track down the real numbers???
    Oct 2008
    Australia
    63
    Well, I have them working ok with the Siemens 80lb data, so I guess it must be close enough.
