I'm working on a 99 Vette w/ a 90mm throttle body. The value in the stock file is 0.0255
What does the ETC area scalar value represent? Is there a good method for changing it for a larger throttle body? Or is it just some simple math?
simple math, smaller number for a bigger TB.
0.0192 is what I have in for my 90mm. It definitely changes idle characteristics.
ls1tuningguide.com has some great writeups, including a spreadsheet for etc scalar resizing for various throttle body sizes
how is this calculated?
I downloaded the spreadsheet "ETC Area Scalar Throttle Body Resizing"
how do you use this information?
going from a stock 78mm TB to a 90mm TB
'02 Corvette
LS6, MN6, LT's/X pipe and TI's, Honker CAI, AI 243 heads, PatG Custom Cam, FAST 102, LS2 TB, Red Top inj, HPTuners & NGK/AFX
is this only something you change on drive by wire cars? Or does this need to be addressed on cable driven also?
1993 reef blue Mustang coupe
Ls1 conversion
1 7/8 cooks headers
AFR 205 heads
Fast 92/92 intake
PAT G./ EPS Custom cam 230/234 .600”/.602” 112LSA +2 advance
century Built 4l60e with Circle D 3500 converter
4.11 gears
etc -electronic throttle control. aka DBW
I thought it was the surface area of the throttle blade in millimeters. Like 4391mm is the value for my stock LS2 Trailblazer. Im not 100% sure though if it is the surface area of the TB blade, or the opening where the TB sits (which is slightly bigger). Maybe someone from the HP team can chime in here.
2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
http://www.dsxtuning.com
Just say no to bull s***.
-Patrick
Click for >>Idle Tuning Guide
Porting doesn't usually intrude on the blade bore, so there's no need to change it.
-Patrick
No.
the scalar is used to convert from Desired Effective Area (mm2) to Desired ETC %.
ie.
100% = TB WOT Area x scalar
I count sheep in hex...
Who know how much etc scalar for 99 LS1 vette with NW102mm tb?
