I am lost I have an 02 Escalade 2 bar OS, I am useing what i think is a ZR-1 map sensor part number GM- 12615136, with the factory liner, and off set, settings from a 08 ZR-1. Linear 312.50 / offset 11.25. I try to scan it and if i use a 2 bar setting in the primary table nothing but 000, If I use the sae vacume map I get 000 to like down to 30 kpa when applying vacum I have cleared all the past car logs reset the scaner reboot it scane priameters but still the same thing I have tryed two maps sensors. I have checked the volts back to the ECM with a fluke and the voltage changes to the ecm but the scanner wont move, and all the wireing is been checked about three times any help would be great i will put up the loges and program
