Strange Fueling Question
I have my car MAF tuned at WOT from 20MPH up and also MAP or VE tuned the same, both which are pretty flat; however when I have both enabled, still in open-loop my AFR is about 8% lean until I get to about 3500-3600RPM. The only thing I can think of is under "Dynamic Airflow / High RPM Disable" is set to 3500RPM; why would this be the cause if both MAF and MAP are flat?
Anyone have an idea why this is happening?
My '06 SS Supercharged
CAI | Front Mount Heat Exchanger | Dual-Pass IC Endplate w/ Opt. B | Ported & Polished LSJ TB | Ported & Polished S/C | 2.9" S/C Pulley | 60lb/hr Injectors | 4-2-1 Header | Catless Downpipe | 2.5" Cat-back | Custom HPtuned | JEGS Oil Catch Can | NGK 1-Step Colder Coppers | Prothane Tranny Bushings | TTR Solid Engine Mount | Progress Rear Sway Bar | AeroForce WB | Interceptor Scan-gauge | ARK Shorty Antennae
