Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: BCM communication!!!!
    Tuner 53mercury's Avatar
    Feb 2011
    Alberta, Canada
    89
    Hi guys I'm back with yet another question...... put a 2008 6.0l with the 6L90 trans in my old chevy all is well except the trans. I can't get any of the inputs to work (tap shift tow haul)! so I figured if I use the BCM from the same truck which controls this then problem solved.... not so! when I hook up my scanner I can actually see the changes I'm making by pushing tow/haul button in the BCM but when I look at the trans data it does'nt change? When I bring up the info in the proccessor (serial#,OS,etc) there is a line that has BCC is this supposed to be the BCM? cause if it is then it's blank! I'm wondering because I turned all the BCM dtc's off it won't communicate? The ECM, TCM, and BCM are all from the same truck no harness has been modified. Without these functions when I tow with it it's always hunting between 5th and 6th gear (big load) and I'm concerned that over time I'll wreck the clutches.
    53 Mercury pickup triton3v V10 supercharged 150 nos 535rwhp
    71 Roadrunner gen 4 viper
    53 Chevy pickup 4x4 5.3L twin turbo
    Tuner Doubledip's Avatar
    Apr 2007
    Sydney, Australia
    151
    dont need a BCM... run a Corvette tune and set it up the same and will work fine
    Ultimate Conversion Wiring
    Quote Originally Posted by Doubledip View Post
    Isn't the tap up/tap down shifting direct wired on a corvette or so I've heard(on this forum I think).
    1968 Bel Air Wagon
    L92/6L80E
    Feb 2011
    Alberta, Canada
    89
    Well I tried that.....no dice! Maybe I don't know how to program the tranny separate! I don't know how to just change the TCM. Did anyone on here do this on a 2008 6L90E? Any help would be welcome cause I still can't get it to communicate.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by 53mercury View Post
    Awe fark. That's generally from an input that isn't supposed to be there or there's one missing. Essentially the BCM needs everything to work that it had on the donor truck, such as ABS, and Speed Sensor Inputs to relay every signal correctly
    618/618 motor
    906/862 spray
    Feb 2011
    Alberta, Canada
    89
    I,m thinking the same cause it is missing ABS,door switches, etc! funny thing is though that it doesn't trigger abs codes (in the BCM)! only codes I get is door switches! I am wondering that because I turned the "U" codes to not turn on the engine light would that stop it from communicating????? If I could get this to work I would also gain cruise control which I presently do not have.
    Feb 2011
    Alberta, Canada
    89
    Man I've tried everything with this even a complete re-write! Maybe GM tech II ? I wondering if it's because I did a complete write without the BCM there to get past the vats... And now it doesn't reconize the BCM!!!!????? Any thoughts out there on this... Very frustrating !
    Feb 2011
    Alberta, Canada
    89
    Any thoughts IDRIVEAG8GT ? You've been very helpful to me before !!!
    Dec 2007
    774
    Post your tune and we can take a look at it.
    Feb 2011
    Alberta, Canada
    89
    Hey guys hope your still sticking around I've been away for a while but here is my tune file..... It is supercharged and having the tranny control would really help !!! I also need to do more tuning on the shifting it bogs for a second when I hammer on it and I think it's the torque management.
    Dec 2011
    3
    Did you make any progress with this? I'm about to swap a LY6 6l90E and would really like to have cruise.
    Mike
    Feb 2011
    Alberta, Canada
    89
    No actually I haven't been busy so not a top priority right now but I would like to cure this annoying problem! Maybe it's something I need GM's tech II to cure....not sure. I know it is on the can bus for sure cause I can see the info on my scan tool but for some reason the PCM ignores it!??!
    Dec 2011
    3
    I read somewhere else that you flashed a corvette program trying to get the corvette style tap shift inputs to work which are hardwired to the trans instead of the BCM like in the trucks. Have you put the truck program back which will look for the truck BCM?
    Mike
    Advanced Tuner Shrek's Avatar
    Nov 2011
    517
    Couple things that may help out ...
    Cruise Control - the E38 is not set up for this functionality. If using an E38 ECM you will need a BCM for cruise control. Some E67 ECMs have the cruise control functionality incorporated.
    Tap Shift - if you are using a truck wiring harness you will need to add a pin / wire to the T43 TCM connector (pin 7 - not used with trucks) to use a TCM Corvette calibration and a hard wired Tap Shift input. This also requires a Tap Shift switch (control box) available from SpearTech. You could make your own if you have schematics, and are comfortable soldering several resistors in series / parallel.
    To use a BCM (i.e. have the ECM recognize its presence) you will probably need to enable the VATS in the ECM tune (its disabled in the tune you posted), then use the Relink VATS function in the software. Just thinking out loud - have never used a BCM with an E38 in a conversion.
    Feb 2011
    Alberta, Canada
    89
    I have spoken to John from Speartech quite a few months ago about the tap option on the 6L90 and he was saying they haven't got tap up/down to work on these trans either! they are working on it. Do you know of anyone that was successfull with this? I am quite confident in my wiring skills for the resistors and have tried running the proper restance for the corvette but I don't know if I used pin 7 or not I'll have to check. It did'nt work! The real kicker would be to get the BCM to communicate that would give me tow/haul as well as cruise control which is as you stated controoled by the BCM. I did do a write entire but did not relink the VATS.......maybe thats it! I'll certainly try enabling the VATS and relinking!!!! Thanks for the info.
    Feb 2011
    Alberta, Canada
    89
    I am running all the 'stock' programming and controllers out of the same unit BCM, TCM, ECM all from the doner truck. I have no idea how to flash a corvette trans tune into my TCM! when I edit anything weather it'd be engine or trans there is nowhere that I can see to change the calibration! how do you put the corvette cal in the truck???
    Potential Tuner sPeeDau's Avatar
    Jan 2012
    Brisbane
    6
    The BCM has to be powered up correctly I don't have the diagram handy right now, but check out the pdf at
    http://944hybrids.forumotion.com/t13...-modifications
    It shows the wiring required for the BCM, cruse and tu td
    Feb 2011
    Alberta, Canada
    89
    Yep all wired up correctly..... it is live and I can use my diagnostic tool (mac mentor) and actually watch as I hit the TU/TD and cruise buttons and see the data change in the BCM but it still won't communicate! I used a GM service manual to wire it as I have the correct cd for the model year.
    Feb 2011
    Alberta, Canada
    89
    Still baffeled by this! Was in contact with John at speartech again and he says that he may have a different OS that "MIGHT" work..... but I don't want to take the chance and loose the info "file" I have now. MIKESZ did you have any luck with yours?
    Dec 2010
    1
    I included the bcm in my ly6/6l90 swap. I needed it for the low speed data lines to communicate with the stock gauge cluster. My bcm was not from the same vehicle and is not linked to the ecm/tcm.
    I have successfully wired the Tow/haul switch and partially wired the TUTD mode but I have not been able to find the schematics for the truck switches showing the size of resistors. But after playing with it I can get it to go into TUTD mode when shifting to the correct range and applying 4K ohm resistor to the TUTD circuit.
    Attachment 33170
    The Tow haul switch is just a momentary ground switch. I assume you wired it to the correct bcm pin but if it is not working your GM lan high speed data lines are not communicating with the ECM/TCM. You need to have the Gmlan signal going into the BCM and out of the BCM, then it should be terminated by a 120 ohm resistor. I recommend you put you DLC after the BCM to make sure it is communicating correctly.
    Attachment 33171
