Results 1 to 6 of 6
Thread: Strange setup help is needed
    Feb 2008
    Pittsburgh PA
    112
    Ok so the car is a 2006 cobalt ss/sc with a zzp turbo swap. s256 turbo running off a tial wastegate no boost controller and a liquid to air cooler. Maf is a blow through setup and has a lk9 saab intake mani with a 2.4l eco throttle body. On 10psi at only 6krpm (42#injectors) Car made 23xwhp. Problem is when the owner leaves and drives home car enters into limp mode every time. I drive it and long it on the street or the dyno and everything runs fine. No idea what is going on here. Is the 2.4tb the issue, blow through maf or something else. He comes back monday and i will post up logs and the tune file. but it wont help since it wont enter limp mode while logging.
    2010 Camaro SS LS3 - Heads, Cam, Whipple 11psi 756whp 663wtq 93 and meth
    Advanced Tuner laser_racer's Avatar
    Jul 2009
    league city tx
    461
    Sounds like throttle body why didn't he stay with lsj? Also can he get service codes pulled?
    Tuner turbo_denali's Avatar
    Jul 2009
    vancouver canada
    51
    P1514 error ? i take it there is no stored DTC i have had P1514, MapvsMAF and many other maybe i can help
    2005 yukon Denali turbo,@15#s 4L80E,1978 z28 lq4,1974 corvette ls6. there is no measurment of power without load.
    Jul 2010
    371
    Quote Originally Posted by laser_racer View Post
    Probably because the LE5 bolts right up and the LSJ would need an adapter.
    1994 Mazda Miata turbo, aero, hoosiers Class=SSM
    Take my drop box referral and we both get an extra 250 Mb free!
    Jul 2009
    league city tx
    461
    Thought zzp modified the manifold for the lsj to bolt up.
    Senior Tuner BackyardTurbo_FTW's Avatar
    Jul 2009
    East Suckburg, PA
    1,163
    It could also be it isn't entering PE mode with mid throttle boosting. Ive seen that happen on a couple cars that were brought to me to fix the tune.
