can you please look at this log and see what you can tell me if anything about the engine burning a hole on piston 5.
As i went through the runs, the AFR stayed pretty rich at 11.8 at some points, the sparks was also 26.5 during the WOT runs.... I am speculating that the fuel pump is to blame since im still running the 98 ls1 OEM one. the thing is I cant see this in the logs....
I already have an upgraded fuel pump from racetronix and their harness to install it once the motor gets back to me. what bothers me is that the AFR looked great during the runs and so did the timing. the car was running very strong and was super peppy.
please look at this and speculate from what you see....I need to get to the root of this bc I cant be going through pistons like this.
