Results 1 to 20 of 20
Thread: Tow/Haul mode for 6L80e
    Dec 2010
    Gonzales, La
    40
    i have a 2008 gmc sierra that is a 6.2/6L80e swap. i have the tow/haul mode through the transmission but i do not have the TU/TD option. i have yet to figure that out past the wiring that is already installed in my truck. basically id have to have the BCM reflashed with a different vin and id have the wrong vin for onstar i think. id settle for my Tow/Haul mode to engage 2nd gear at a low roll vs having TU/TD, then have it shift through the gears like normal at WOT. has anyone done this with the 6L80e yet?
    thanks
    2008 6.2/6L80e swap
    Tuner TimC's Avatar
    Jun 2009
    Near GR, MI
    198
    You can tune the shift mph in normal and tow/perf mode separately with HPtuners. TUTD sucks, it's not worth screwing around with the wiring.
    1971 Corvette-LS3 swap with custom cam. Stainless headers and sheet metal intake built by the owner. 442rwhp.
    2007 STS-V-Billet Precision 67mm turbo swap. 563rwhp@15psi.
    1991 Camaro-6.0 swap with LS6 heads and custom cam. Headers and other swap bits fabricated by myself (wife's car)
    Dec 2010
    Gonzales, La
    40
    i do have the wiring already in my truck factory, all i would have to do is have the dealer program the bcm but id lose other fuctions that i want. The is no tow/haul tab in the software that i know of other than performance, so how would i set it to select 2nd gear when i press the tow/haul button?
    2008 6.2/6L80e swap
    Tuner TimC's Avatar
    Jun 2009
    Near GR, MI
    198
    The performance shift settings should be active when the tow button is pressed. You could change the shift speeds to how you want them that way.
    Dec 2010
    Gonzales, La
    40
    thank you for you help!
    2008 6.2/6L80e swap
    Dec 2010
    Gonzales, La
    40
    this is the only 2 tabs i have as a "shift pattern" under *Auto Shift Properties, General tab*
    so i would have to change the "cruise" one to performance an go from
    there?
    2008 6.2/6L80e swap
    Tuner TimC's Avatar
    Jun 2009
    Near GR, MI
    198
    Post your tune and I'll look.
    Dec 2010
    Gonzales, La
    40
    yes sir but can you tell me how to?
    2008 6.2/6L80e swap
    Dec 2010
    Gonzales, La
    40
    Attachment 29909
    i dont know if that works....
    2008 6.2/6L80e swap
    Dec 2010
    Gonzales, La
    40
    any luck?
    2008 6.2/6L80e swap
    Tuner TimC's Avatar
    Jun 2009
    Near GR, MI
    198
    I don't know what to do there. I don't recommend changing any of the stuff HPtuners says not to change. You don't know if there are tables you can't see that will affect the changes in a negative way. I guess you can try to get the TUTD working like you originally thought.
    Dec 2010
    Gonzales, La
    40
    Quote Originally Posted by TimC View Post
    Yeah i dont want it to blow up muchless break anything
    2008 6.2/6L80e swap
    Dec 2010
    Gonzales, La
    40
    i got it working thanks to Wheatley
    2008 6.2/6L80e swap
    Tuner TimC's Avatar
    Jun 2009
    Near GR, MI
    198
    Post up what you did so future swappers can see it.
    Dec 2010
    Gonzales, La
    40
    I dont really know what he did lol it all looks the same to me. Ill post the new tune tomorrow when i get home
    2008 6.2/6L80e swap
    Jul 2011
    Pasadena, TX
    39
    "Wheatly" houston tuner???
    Dec 2010
    Gonzales, La
    40
    Quote Originally Posted by jguev View Post
    Yes, but it is spelled "Wheatley"
    2008 6.2/6L80e swap
    Jun 2017
    1
    What did you have to change to get it to work?
    Dec 2021
    1
    did i miss something i dont see the fixed tune
    Jan 2014
    SoCal
    1,565
    If you go to trans 460 and 461 (CTRL + N) you can select different options for shift scheduling. It is like having different transmissions based on a few parameters like tow haul mode, cruise control engaged, performance, etc. Then go to 15315 and 15319 and do your trans tuning individually.
